Question about Canopus ADVC-110 A/D Converter (77010150105) Video Capture
Analog and Digital selections lit up, status light flashing
Lost the DC power cable and am using another 5V power cable. Am not able to select between digital in and analog in, both are lit up
  • yo_quiero_ta Jun 23, 2009
    Probably connected wrong wires. Thanks
    Scholar:
  • 122 Answers
Although you are using another 5v cable, please make sure that the AMPS are correct. Look on the back of your Canopus and see if it lists the amps along with voltage. Too liitle or too much a,perage will cause malfunction.
Posted on Jun 23, 2009
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung HLP5685 W
yeppers..the ballast has taken early retirement...can you unplug the ballast output, and see if it's running into a short condition?
Mar 09, 2008 | Samsung HLP5085W 50" Rear Projection...
I have a Lynx system with a 5828 wireless keypad that I have connected a 5v transformer to it to keep the keypad lit always. The keypad does not stay lit always and it keeps going to sleep after 10...
It sounds like your 5V transformer isn't working. It could be the outlet it is plugged into isn't working, or the outlet is on a light switch that is turned off, or there is a problem with the keypad itself. The user manual says:
"AC-Powered Operation: When powered by the
optional AC adapter, the keypad remains active at all
times. If AC power is lost, the keypad reverts to
battery-powered operation until AC power is restored
On AC powered units you can get the status by viewing
the display."
The only way I know of to keep it active is by using the transformer.
Hope this helps.
Mar 22, 2011 | Ademco 5828 Wireless Keypad Lynx / Vista...
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
No digital only analog
Ok,
1. Press MENU to display menu screen, and press c/d to select "setup".
2. Press a/b to select " CH setup", and press enter.
3. Press a/b to select "air/cable", and then press enter.
4. Press c/d to select "cable", and then press enter.
5. Press a/b to select "Analog & Digital Search Start", and then press enter
6. Press menu to exit after search is finished.
This should fix the problem. You'll have to repeat this steps to update the TV everytime the cable company changes the channels to digital.
Feb 03, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Archos Gmini220 Power Supply?
The charger which came with my Gmini 220 is 5V DC, 1.6A. It measures about 5.18V. The +5V is applied to the normally unused pin on the USB connector. The charger's plug is built so you and plug the charger into the Gmini and then plug the USB cable into the charger.
Aug 01, 2007 | Archos Gmini 220 MP3 Player
Cannot Log on to my Router
These steps solve most of the problems with logging on to routers. 1. Connect a computer and a router directly with an Ethernet cable, putting an end in one of the router's LAN ports. Check that both ends are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot the light status, as explained in the manual. 3. Check that the LEDs for the ports with cables are lit. If they are not, try moving the cable to a different port. If there are still no lights, then troubleshoot the light status, as explained in the manual. 4. Check the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue with this document. If the Ethernet adapter was not made by NETGEAR, contact the adapter's maker. 5. Select Start > Run. Type cmd. Type ping 192.168.1.1. If there is a message "Request timed out", type ping 192.168.0.1. If that also has a "Request timed out" message, then your computer is not making a connection to the router. 6. Otherwise, your computer is connected to the router: * Make sure proxies are not enabled. If using Internet Explorer, select Tools > Internet Options > Connections > LAN Settings. Uncheck "Use a proxy server for your LAN....". * Delete offline contents. Select Tools > Internet Options > Delete Files. Select Delete all offline content, and click OK. (This is to clear any possible previous router log on page.) * Try accessing with a different computer, or with the Netscape browser, if you have it. * Delete cookies. WARNING. Do not do this if it's possible Web sites you visit need cookie information such as your logins and passwords. 7. Power off the router, and power it back on again. 8. If you still cannot log on to the router, then do a hard reset on the router. (Described here: http://www.fixya.com/ThreadView.aspx?thi...) 9. If you know how, check the computer's IP address and DHCP. The IP should be in the 192.168.0.x range, and DHCP should be enabled.
Feb 19, 2006 | NetGear RP114 Router
These steps solve most of the problems with logging on to routers. 1. Connect a computer and a router directly with an Ethernet cable, putting an end in one of the router's LAN ports. Check that both ends are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot the light status, as explained in the manual. 3. Check that the LEDs for the ports with cables are lit. If they are not, try moving the cable to a different port. If there are still no lights, then troubleshoot the light status, as explained in the manual. 4. Check the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue with this document. If the Ethernet adapter was not made by NETGEAR, contact the adapter's maker. 5. Select Start > Run. Type cmd. Type ping 192.168.1.1. If there is a message "Request timed out", type ping 192.168.0.1. If that also has a "Request timed out" message, then your computer is not making a connection to the router. 6. Otherwise, your computer is connected to the router: * Make sure proxies are not enabled. If using Internet Explorer, select Tools > Internet Options > Connections > LAN Settings. Uncheck "Use a proxy server for your LAN....". * Delete offline contents. Select Tools > Internet Options > Delete Files. Select Delete all offline content, and click OK. (This is to clear any possible previous router log on page.) * Try accessing with a different computer, or with the Netscape browser, if you have it. * Delete cookies. WARNING. Do not do this if it's possible Web sites you visit need cookie information such as your logins and passwords. 7. Power off the router, and power it back on again. 8. If you still cannot log on to the router, then do a hard reset on the router. (Described here: http://www.fixya.com/ThreadView.aspx?thid=102071&prdid=252225) 9. If you know how, check the computer's IP address and DHCP. The IP should be in the 192.168.0.x range, and DHCP should be enabled.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Open Questions:
Canopus ADVC-110 A/D Converter (77010150105) Video Capture Logo
445 people viewed this question
Top Canopus Televison & Video Experts
Alun Cox
Troy Staley
Troy Staley
Paul Bade
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
