Question about Motorola Mobility RAZR V3
My time doesnt change at daylight savings time
I time changing it manually but it doesnt work
  • 6 more comments
  • Anonymous Nov 04, 2007
    the time on my phone did not update when daylight savings ended...I can't figure out how to do it manually...can I?
    i can't get the time to change on mine either. i went into initial setup and there is no date and time adjustment.
    thsi blows.
  • busymomof4 Nov 04, 2007
    My time didn't change either, looked in the manual and my phone is on auto update, so it should change on its' own.
  • doodyroot Nov 05, 2007
    that did not work I turned it off and its still the same time
  • Anonymous Nov 06, 2007
    the problem is, when i go to the initial set-up menu, there is no tab for time/date etc. my phone did eventually reset, but not until 10am my time.
  • Anonymous Nov 15, 2007
    folks, again, there is NO "date and time" option om my V3Cm. the initial setup menu has the following options;
    Speaker Phone
    Auto Redial
    Display Timeout
    Backlight
    TTY Setup
    Scroll
    Language
    Batter Save
    Brightness
    DTMF
    Hyphenation
    Master Reset
    Master Clear
    i have been through all the options and cannot find a way to modify the time. is it hidden somewhere in here? please don't tell me to find the date and time option, i wouldn't be on an internet help page if it was that simple, i'd be in an institution.
    regards.
    D
  • Anonymous Nov 03, 2008
    Daylight savings was yesterday and my phone still has not updated itself!!!!
    What can I do to change it!
  • Anonymous Mar 17, 2014
    cannot get tv to change time to correct time in New South Wales (daylight saving)
Go to settings,initial setup,time and date. change it to "off" on autoupdate.You'll get more options. You can change the date and time then.
Posted on Nov 05, 2007
Lol all you have to do is turn your phone off and the time will be updated to daylights savings once you turn it back on.
Posted on Mar 09, 2008
Go to settings, initial setup, time and date, from there you should be able to set the time.
Pretty weak that it doesn't auto update though.
Posted on Nov 09, 2007
    Problem Solver:
  • 8 Answers
On a Motorola Razr V3 there is ** Time and Date option unless u take it to a service provider and tell them to add that option but to fix this daylight savings problem you should Turn your phone On and Off and it should update automatically
Thnx this post helped me out fast!!!
Setting the Time and Date
You must set the time and date to use the datebook. In some areas the network will update the time and date automatically.
Menu Key > Settings > Initial Setup > Time and Date
The Menu Key is the button above directional circle with the bold dash in the middle of it. There is no button above it. It is right below the screen.
To update time: I contacted Motorola and was told to turn my Razr off and turn back on and it would auto update...it did:)
Posted on Nov 04, 2007
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
HELLO MY CLOCK DID NOT DO AUTO DAYLIGHT TIME HOW DO I FIX THE TIME TO ADJUST TO ONE HOUR A HEAD THANK YOU INGER WELCH
All you need to do to advance your clock an hour for daylight savings time, is hold down your clock button without letting it go. Then press your hour button once and you should be all set.
Most clocks that are older than when they changed the date of daylight savings time will either not change it for you on the right day anymore. Or they don't have that feature in it.
If yours does have an automatic daylight savings feature...you may find it helpful to take it off "automatic" and just change it manually from now on. That's what I do with my VCR. It has an automatic daylight savings time feature, but it's useless now that they have changed the date when we set our clocks for DST.
Some manufacturers will give you instructions on how to change the feature settings so your product will again work correctly for you. But not all will or can. You can look it up at your manufacturers website to know for sure.
Good Luck...and I hope this helps you.
Mar 13, 2011 | Vacuums
The clock changes for daylight savings time on the wrong day. it did this the past few times the time had changed. the date on the back of the unit is 2004. didn't they move the weekend of daylight savings...
Daylight Savings Time was extended in 2007.. (the Act was in 2004)..
So your clock worked fine for three years.. now.. if you can turn this automatic feature off I suggest you do and just set it manually... otherwise you will make the change.. and it will make it again for you!
Best of luck
Mar 12, 2011 | Vacuums
Can not open programs since daylight saving tme has change. All programs were converted to something else. I cant get into to change daylight saving help!
Time change has no effect on programs working.
Try changing time in control panel Time&Date link?
Manually run the internet time updater?
What do programs look like they were converted into?
Different language? Check Language settings?
Hard Drive got corrupted? just a coincedence?
Apr 04, 2010 | ZT Group CISNET A7022 PC Desktop
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
I installed the Pioneer AVIC-F900BT and it has been
Windows CE is used to operate the Pioneer AVIC F series, which yours falls into. That version of Windows has not been patched or updated with the new day light savings times and since the player uses GPS to get the current time and Windows to make the time change for your zone then your time will not update until the orginal daylight savings time occurs. You can try to change the time to manual in the Pioneer settings, deal with the wrong time for just a lil bit longer until the original Daylight Savings Time takes place, or re-search an update and way to update the players OS which is Windows CE. Hope this helps :)
Mar 10, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
Imate Jamin - daylight saving error
Yes - i had the same problem.
Goto microsofts download area, and download the patch for windows mobile (assuming you are using v5.0 or v6.0).
The patch is:
http://www.microsoft.com/downloads/details.aspx?FamilyID=0D6FC192-3142-4473-B435-B514E4B360A5&displaylang=en
I've just installed it as per their instructions and it worked perfectly
Mar 16, 2008 | Lands Phones
Daylight saving time auto change over
call 18006954820 they will walk you through
Nov 02, 2007 | Timex T276B Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Motorola Mobility RAZR V3 Logo
1,082 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
