Question about Hardware & Accessories
How to set a sat-r model hy-mac timer
The timer has two sets of numbers, with yellow, movable links. how do you set it to start at 18H00 and stop at 22H00?
2 Suggested Answers
  • 5245 Answers
SOURCE: how to set Hy-Mag pool timer switch
Be real.
Describe the timer in detail, and include the model number and take a photo and post on flickr.
Add a comment with missing information.
Is this a timer, or circuit breaker?
Posted on Oct 09, 2012
I have a vintage Hy Gain Hy Power microphgone, model 610, that I would like to connect to a Kenwood 440 SAT HF transceiver. Please tell me what to connect where on the Kenwood 440 SAT mike plug.
White is the MIC wire
Copper shield is GROUND
Black is usually PTT, otherwise use RED for PTT
vpaxi2bbtoaaaaaelftksuqmccaa==
The above drawing is the TS-440SAT mic connector pinout. The pin numbers should be visible on the MIC connector.
You can get the complete manual at www.mods.dk for free.
Sep 03, 2017 | Kenwood Radio Communications
I have a Kenmore series 600 waaher model 110.27642600. The Permanent Press cycle doesn't work. The water comes in but the timer doesn't advance. All other cycles work OK.
The washing machine timer can be considered the brain that controls the washing machine's systems. Although timers are ruggedly constructed, they contain a variety of tiny parts, like springs and movable contacts, that can develop problems that keep the machine from operating properly. The movable contacts can become burned and fuse together or they can become stuck in the open position, thus disrupting the wash cycles. The timer's motor can also become defective, thus preventing the timer from advancing through its cycles.
a defective timer motor, the motor's control contacts stuck in the open position or defective drive gears. Unplug the timer's wiring harness, then, with the timer set to any position other than off, check for continuity through the motor contacts. Continuity will be indicated by a "0.000" on the meter's display. A pictorial diagram on the back of the machine will tell you which numbers on the timer socket corresponds to which set of contacts in the timer. Likewise, a functional timer motor will display a resistance reading greater than 0.000, but less than 5 ohms. Open contacts or a defective motor winding will be indicated by an "O.L." on the meter's display.
IF A defective timer will only work in some cycles and not others. Then check for a broken wire in the wiring harness, check for continuity through those contacts using your meter. Wires in the wiring harness can break, but it's not a common occurrence unless they get pinched during the assembly of the machine.
If the same part of each cycle setting, such as the spin cycle does not operate properly, the problem probably is not the timer but some other component such as the transmission shifting mechanism. If the problem occurs when using only one cycle setting, the problem is a bad timer.
Apr 10, 2017 | Kenmore Washing Machines
I have a mac. how do i set up so i can start printing
Go to Canon website put in your printer model number an get the drivers an software for mac! hope this helps !
Sep 26, 2016 | Canon 3811B007AA model imagePROGRAF...
How to set Hy-Mag pool timer switch
Be real.
Oct 09, 2012 | Hardware & Accessories
I do not know how to set it. i have lost the instructions for a 111woods model tn300
Woods timers sometimes have more than one number for same timer.
This is true for most brands of timer.
Companies change model numbers and add new model numbers.
Intermatic makes two different analog timers with 111 model number. TN111 and HB111.
Grasslin has older electronic timer Tactic 111
Timex sells TE111 timer.
Open following link to identify TN300 analog timer and read instructions and download possible manual:
If TN300 is not same as your timer, view images on link and then add a comment for possible help with different timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Open following link for instructions how to set analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Sep 02, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I need instructions for how to set a 24 hour mechanical General Purpose timer. My model #15075
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Oct 25, 2010 | Electric Eyeware Ge 24 Hour Electric...
Need red plastic timer clips for my ML600TW. Transformer works, but only have one red movable clip for setting a time. Timer may be broken, but would like to try installing the on/off clips first. Any idea...
Open following link for ML power pack trippers, plus troubleshoot, plus tips to keep power pack from burning out, and warranty:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 04, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
The timer was a little tough to get started sometimes, I'd have to pull the knob out and push it back in several times before it would start.
The start switch is going out. You will have to replace the whole timer on this model. Check the first 2 numbers of your serial number if it is 10 - 15 the part number is 33002855 if the first 2 numbers are 16 or greater the part number is 33002803. Please rate me after reading.
Dec 13, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Hardware & Accessories Logo
79 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
