Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
Oven shelves noty wide enough and collapse when removing hot food, dangerous
2 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Oven not hot enough
the thermometer is most likely the problem, the calibratation is probably off. If you have access to a accurate digital thermometer it is relatively simple to do. If you do have one just take and set the knob to 250 degrees and when the oven gets to 255 it should go off and come back on at 245 degrees. If it's a digital there shopuld be a potentiometer that you have to adjust. good luck
Posted on Dec 26, 2008
Steve is replacing 9 shelves in a cabinet that is 212 feet wide. He purchased 3 8-foot boards to make the new shelves. How much board will be left over after Steve makes the new shelves? feet
Not enough info... or not enough wood.
Never saw a cabinet 212 feet wide- almost as long as a football field .
I'm going to assume you meant 2 and 1/2 feet wide. If so, each 8 foot board can be cut into three 2 1/2 foot shelves (leaving 1/2 foot left over). Do same 3 time yields 9 shelves and three 1/2 foot boards - a total of 1 1/2 feet left over.
Dec 03, 2017 | The Office Equipment & Supplies
Oven hot when I unplug it
Well of you just used it than that would be why. Heat doesn't just magically go poof
Nov 17, 2014 | Kitchen Ranges
Are food warmers dangerous?
Domestic food warmers usually reach a high enough temperature to heat food but not high enough to kill bacteria, therefore creating an idea breeding ground for it.
For this reason it is best to have small quantities of food being served on food warmers at once. The best is to serve it quickly and remove it from the tray as fast as possible. After two hours that the food sits in the warmer it has to be thrown out.
Another danger could be the heated tray and hot water, in case there are childray round, that could get burnt.
Dec 30, 2013 | Kitchen Appliances - Others
I have a Sunbeam SMO701A7E microwave and I want to permanently turn off all beeps ( food ready, food still ready, even start and stop) Is this possible?
Without physically cutting the wires to the sounder, no. If you remove the sounder, it will become possibly dangerous as one will not know, if not remembering, that the food inside is hot or cold and could cause an accident or food poisoning if not cooked properly.
Feb 23, 2011 | Microwave Ovens
Oven shelve falls
You are right, this is very dangerous. It is possible that your oven walls expanded, but honestly, I've never heard of this before, but this is what it sounds like!! I would call Sears right away and have them come out and check it. If the walls did expand, you have a defective oven and they should recall that model. I'd really love to hear the outcome of this complaint, so please let me know how everything turns out for you. And you better get it repaired before Thanksgiving. Have a great day!
Sep 07, 2009 | Ovens
Shelves not wide enough to stay on shelve supports
your ansewer for not the rade qus,,,,,,,,,,,,,,,,,,,,,,, ok
May 22, 2009 | GE EasyCam Webcam
Smoking Fan Assisted Oven
Is the smell a food smell or other smell. If it is food, then some food has gotten behind the blower motor. Clean behind it good. Even some small particles have gotten in there somehow. You can also feel thye sufaces of the oven and tell if there is some buildup.
Jan 20, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Freezer Shelves are too small for freezer and keep falling when I put food on them...
I had the same problem with the freezer sheles being too small in my GE Profile side by side. The shelves would simply collapse down with any weight on them.
After measurng the gap, I determined that the shelves were approximately 7/16" too narrow.
The fix I did was simple, effective, and very cheap.
I bought a roll of clear flexible polyethylene tubing at Lowes for about $5.The tubing is 3/8" outer diameter, 1/4" inner diameter (see picture below).
I cut pieces to fit along the side rails of the shelf, and then sliced the tube pieces down their length with a utility knife. I wrapped the pieces around the outside rails on each side of the shelf. It took a little work, but I got the tube pieces attached.
In a few spots, I did a double wrap of tubing.
The shelves fit tightly now and can hold significant weight without collapsing. Plus, they don't look too bad.
I hope GE fixes this simple problem in the future.
2_29_2012_2_35_52_am.jpg2_29_2012_2_36_07_am.jpg2_29_2012_2_36_33_am.jpg2_29_2012_2_36_53_am.jpg
Jan 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Open Questions:
See all Kenmore 46123 Stainless Steel Electric Kitchen Questions
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
