Question about Citizen CD-S500 Dot Matrix Impact Printer PC Desktop
My CD-S501A printer will not feed the paper. The stepper motor does not turn and is connected to the print head motor and board. What do I do now? Its only 6 months old.
    Problem Solver:
  • 6 Answers
Uninstall your printer and again install.
then reboot your pc
Posted on Jun 26, 2009
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
Tally T6212 paper motion fault. Replaced top tractor with paper motion sensor. Found motor not turning at all. Replaced paper motor and power distribution board but its still not turning motor and not...
Did you check the different voltages coming (or should come) out of the power supply?
When a display works, will not implicate the power supply is working correct. It is too long ago I worked with these kind of printers, but I don't think the stepper motors need a capacitor. The caps can be defect, and can cause the loss of one or more output voltages.
Jul 09, 2014 | Office Equipment & Supplies
Error code 5100
There is no error 5100 in the manual so look at the following:
(1) Operator call errors (by LED blinking in orange)
LED blinking in orange. Error Solution Remarks
2 times No paper. Set paper, and press the Resume/Cancel button.
3 times Paper jam. Remove the jammed paper, and pressthe Resume/Cancel button.
4 times No ink. Replace the empty ink tank(s). (Pressing the Resume/Cancel button will exit the error without ink tank replacement.)
5 times The print head is not installed properly. - Install the print head, and close the
front cover.- With the print head installed, turn theprinter off and on.
- Re-install the print head.
8 times Warning: The waste ink absorber is almost full (approx. 95% of the
maximum capacity). Pressing the Resume/Cancel buttonwill exit the error, and enable printing.
In repair servicing, replace the bottom case unit (QM2-0647), or 5-item set of
the ink absorbers
(QA4-1012/1013/1014/1015/1055).
9 times The connected digital camera or digital video camera does not support
After removing the cable between the camera and the printer, press the Resume/Cancel button, and re-connect the cable.
(2) Service call errors (by LED blinking alternately in orange and green, or lit in
orangeLED alternate blinking in orange and green
Error Solution
(Replacement of listed parts, which are likely to be faulty)
2 times Carriage error - Carriage unit (QM2-0655 / QM2-0831)
- Timing **** strip film (QA4-1053)
- Logic board ***'y (QM2-0750 / QM2-0751)
- Carriage motor (QK1-0175)
3 times Paper feed error - Timing sensor unit (QG4-0277)
- Timing **** disk film (QC1-2781)
- Feed roller ***'y (QF4-0155)
- Platen unit (QM2-0650 / QM2-0828)
- Paper feed motor (QK1-0224)
4 times Purging error - Purge unit (QM2-0825)
6 times Internal temperature error - Logic board ***'y (QM2-0750 / QM2-0751)
7 times Waste ink absorber full - Ink absorber (QA4-1012 / 1013 / 1014 / 1015 / 1055)
- Bottom case unit (QM2-0647)
8 times Print head temperature rise - Print head (QY6-0042)
9 times EEPROM error - Logic board ***'y (QM2-0750 / QM2-0751)
13 times USB Host VBUS overcurrent - Logic board ***'y (QM2-0750 / QM2-0751)
- DCD board ***'y (QM2-0825)
15 times Other hardware error - Logic board ***'y (QM2-0750 / QM2-0751)
Flash ROM error - Logic board ***'y (QM2-0750 / QM2-0751)
Lights in orange
RAM error - Logic board ***'y (QM2-0750 / QM2-0751)
Hop you can understand the above as it is straight out of the service manual.
Good luck
May 24, 2011 | Canon BubbleJet i560 InkJet Printer
Getting code 6000
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board or Paper Feed Motor or Paper Feed Roller Unit
May 27, 2010 | Canon PIXMA MP620 All-In-One InkJet...
The yellow lamp is flashing and printer dosn't work .My printer is pixma mp510 canon
How many times does it blink... 2, 3, 12....
2 times Carriage error [5100] An error occurred in the carriage encoder signal. - Carriage unit (QM2-3753)
- Timing **** film (QC1-9542)
- Logic board (QM2-3827)
- Carriage motor (QM2-3872)
3 times Line feed error [6000] An error occurred in the LF encoder signal. - Timing sensor unit (QM2-3878)
- Timing **** disk film (QC1-9597)
- Feed roller (QL2-1407)
- Paper feed motor (QM2-3873)
4 times Purge cam
sensor error
[5C00] An error occurred in the purge unit. - Purge unit (QM2-3754)
5 times ASF (cam)
sensor error
[5700] This error takes place when feeding paper from the
ASF after an error occurred in the ASF cam sensor.
- Sheet feed unit (QM2-3762)
- ASF_PE sensor board (QM2-3877)
6 times Internal
temperature
error
[5400] The internal temperature is not proper. - Logic board (QM2-3827)
7 times Ink absorber
full
[5B00,
5B10,
5B01,
5B11]
The ink absorber is full.
Error codes:
Overseas:
5B00: Main ink absorber
5B10: Borderless-print ink absorber
Japan:
5B01: Main ink absorber
- Ink absorber kit (QY5-0178)
1-5
Note: Before replacement of the logic board ***'y, check the ink absorber counter value (by service test print or EEPROM information
print). If the counter value is 7% or more, also replace the ink absorber kit (QY5-0178) when replacing the logic board ***'y, or
register the current ink absorber counter value to the replaced new logic board instead. [See 3-3. Adjustment / Settings, (9)
Service mode, for details.]
2-3. Other Error Messages
5B11: Borderless-print ink absorber
8 times Print head
temperature
rise error
[5200] The print head temperature exceeded the specified
value.
- Print head (QY6-0070)
9 times EEPROM
error
[6800] A problem occurred in writing to the EEPROM. - Logic board (QM2-3827)
10 times VH monitor
error
[B200] The internal temperature exceeded the specified
value.
12 times PG position
error
[5C10] An error occurred in the PG motor during purging
operation.
15 times USB Host
VBUS
overcurrent
[9000] The USB Host VBUS is overloaded. - Logic board (QM2-3827)
19 times Ink tank
position sensor
error
[6502] None of the ink tank position is detected. - Spur base unit (QM2-3750)
20 times Other
hardware error
[6500] The PCI bus error is detected by the ASIC. - Logic board (QM2-3827)
22 times Scanner home
position error
[5010] The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on.
On the LCD, "Scanner is not operating correctly." is
displayed.
- Scanner unit (QM2-3775)
Alarm and Power
LEDs lit
ROM error,
RAM error
A flash ROM or RAM checksum error occurred at
hard-power-on.
Jan 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
SAME PROBLEM LEXMARK X2350 STARTS FEED PAPER AND PRINTER HEAD MOVES AS PRINTING BUT WILL NOT FEED PAPER WHILE PRINTING? ARE THERE 2 FEEDERS IN THIS PRINTER? HOW TO FIX?
transfer roller that starts the paper and feed that feed the paper. have you had a paper jam and torn a piece of paper off inside the feed mech? i dont remember if this one feeds off the motor or a belt. either way you would have to disasemble the printer to determine where the problem lies. might be more econimical to replace the printer.
Jul 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Dec 12, 2008 | Xerox Phaser 6110 All-In-One Laser...
Cartridge jam in my Kodak EASYSHARE Series 3
The print head must be in the up position to remove the cartridge. If you cannot get it to do this by pushing buttons or unplugging the unit, you can do it by turning a gear inside the unit. This requires partial disassembly of the unit.
First remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. You do not need to disconnect the fan wires.
The print head heat sink and carrier frame are now visible (large aluminum piece in the center). The gears and stepper motors are on the side opposite from the green cartridge release button. The gears near the front operate the paper feed mechanism. The gears in the back move the print head. By turning the large white plastic gear farthest toward the side and rear (driven by a stepper motor), the print head will move up and down. The gear should turn easily by pushing on the teeth with a small screwdriver. If it starts tuning harder, it is probably at the end of its travel. Turn the gear until the print head is up far enough to release the cartridge. There is a tab on the print head frame just above the green release button on the inside of the unit. When the print head is up, there is a space between the tab and the green button allowing the button to be released.
If you need more visibility, the entire printer frame can be removed from the plastic outer shell by removing 3 screws on the bottom of the unit. Note the position of the loose plastic piece in the front of the unit (for reassembly). It has a small tab that keeps the front door closed. You can leave the print head in the up position when reassembling the unit. It will automatically reposition when the unit is plugged in. Don't forget to put in a cartridge before plugging in.
Aug 08, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
Paper will not feed into printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Citizen CD-S500 Dot Matrix Impact Printer PC Desktop Logo
159 people viewed this question
Top Citizen Computers & Internet Experts
NOEL
NOEL
john h
Marvin
Marvin
Are you a Citizen Computer and Internet Expert? Answer questions, earn points and help others
