Question about Digi 2.5 lb x 0.0002 lb AC/DC Digital Counting Scale, (HPCS274219)
What is load cell of digital scale? - Digi 2.5 lb x 0.0002 lb AC/DC Digital Counting Scale, (HPCS274219)
What does Errh mean?
Display - (ErrH) Errors - The value counted at zero point is too small.Items to be checked - Distortion of the load cell assembly.Repair & replacement methods - Replace mechanical assembly.BASICALLY - The error mention relates to a distorted/damaged loadcell. It will be uneconomical to repair this unit.
Aug 21, 2012 | Tanita 1479V - Digital Pocket Scale /...
Error sign when turning it on. New batteries where installed
Possible that the LOAD CELLS are defective. Please check the main power and the feed to the processor and if the voltage are correct, then check for mechnical jamming of the tray . If there is no there observation , the fault can be the load cells. Estimate the cost of new cells, if possible get a trail piece for confirmation.
Sep 23, 2011 | RTO Us Balance Usx-500 Digital Scale
Our Weight Watchers scales have suddenly stopped giving us a correct weight - both my husband and myself are showing weights of 6st.5lbs and we are very much heavier than that - can you solve the problem? ...
It ispossible that the LOAD CELLS are damaged or there is a fault in the mechanism that is jammed and not reacting to the weight loaded on the tray. So remove and check if this is free and the depression is noticable. If so the LOAD CELL must be replaced.-- hoping that the main control board- processor is OK.
Sep 22, 2011 | Conair Weight Watchers WW-87 Body Fat...
Scale is reading F--H
Mine did this also, I got a replacement and it also read F--H. I took all the screws out - they hid them under the bar code sticker and under the stick-on faceplate where the buttons are - then found that the screws on the load cell which is sort of like an aluminum tuning fork had been tightened so much that the cell was reacting to the screw force, not the scale pad. Release all the pressure and you may be able to make it come alive again. One of my two is working now but calibrating is another thing all together because the linear counting depends on the loadcell screws being set just right.
Jun 03, 2011 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
ERR12 AND16 KEEP COMMING UP NEW SCALES unable to reset
Err 12 Inital load is too high power on zero point outside permissible range
Err 16 No zero point available, unable to calculate weight
Check no load on platform
Check the sensor this could be defective. This is the most likely
Sep 02, 2010 | Seca 354 Digital Baby Scale Pediatric...
Scale appears to be inaccurate
this type of less resoluted scale hasn't repeatability. if you wish to repair it, change the loadcell. use 2 x scale capacity of load cell.
Nov 26, 2008 | Conair Weight Watchers WW-87 Body Fat...
Digital scale
if scale  shows 0.000 after placing some weight on pan, it means sensor or load cell connection is open, please check sensor connection.
Mar 23, 2008 | Digi 2.5 lb x 0.0002 lb AC/DC Digital...
Computers & Internet Logo
Top Digi Computers & Internet Experts
Matthew Spark
Matthew Spark
doggzzz
Level 1 Expert
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
