Question about Dell Studio Slim-Tower Desktop Computer
How do i connect my lcd tv to dell optiplex gx620 computor using hdmi to vga cable
    New Friend:
  • 30 Answers
You need to match the connectors, very likely your TV has HDMI or DVI, so use the external video port in the computer, DVI or HDMI, you can buy a cable with a match to the video connector you have in both devices.
Posted on May 23, 2014
bschilz
  • 2049 Answers
SOURCE: i have a dell optiplex gx620 and it wont turn on
As you can imagine, this is not simple thing to diagnose.
First, we need to try Dell's steps to fix...
Remove non-essential peripherals…
Except for the monitor, keyboard, and mouse, remove all external peripherals including:
  • Scanner
  • Printer
  • Modem or Network cables
  • Personal Digital Assistant (PDA)
  • USB flash drive or other external Hard Drive
  • Any other external devices (e.g., USB-attached devices)
  • Remove the computer from the docking station, if you are using one
  • Scanner
  • Printer
Try rebooting. If that doesn’t work, Dell states you need to do the next step.
Remove and Reseat Basic Hardware items:
  1. Power Cord
  2. Memory
  3. Hard Drive
At this point, Dells says if that fails contact them.
If my hunch is correct, you may have something on the motherboard shorting a connection or you have a blown capacitor. Get some “canned air” and blow out the computer thoroughly. Some people have reported the same symptom having dust or other debris causing the issue, so give it a good blowing out,
At the same time, inspect your motherboard thoroughly for an anomalies. If you see anything resembling the picture below, you have a serious motherboard problem which will require replacement.
Posted on Oct 20, 2009
yngwei50
  • 134 Answers
SOURCE: Adding network drivers to dell optiplex gx620
Just download the drivers here the link http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=PLX_PNT_P4_GX260
Posted on Dec 18, 2009
SOURCE: How to open the case
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtcvrop0.htm#wp1051283
Posted on Mar 08, 2010
  • 113 Answers
SOURCE: Windows 7 drivers for Optiplex GX620
for drivers u visit driversdownload.com, register and then dowload required drivers for ur comp. i doubt ur computer is affected with virus. pls check it also
Posted on Jul 14, 2010
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
How do i use my tv sa a monitur for my pc but has no VGA on the back just a HDMI plug and scart socket.
Chris, what happens when you plug the hdmi connector into the TV and your adapter, while your computer is running and connected to the adapter?
Are there drivers required for the adapter?
As an alternative, you could install a video board in your Dell that includes an HDMI output. I have a laptop with one, and connect it to my TV often; works fine.
Jun 19, 2015 | Dell OptiPlex 745 Desktop/ Mini-Tower/...
Can i use my tv as a monitor for my home computer (Dell Optiplex 745)and if so how. I tried difrent ways and cant seam to do it.Help. Please. Chris.
The TV should have VGA input socket to connect with. if have; you can connect the TV with the computer, using a VGA to VGA cable.
VGA input socket.
VGA - VGA cable
25737496-zeccwmaoed3oumaueic5tnov-2-2.jpg http://electronicshelponline.blogspot.com/
Jun 09, 2015 | RCA Televison & Video
How do i connect my lcd tv to dell optiplex computor using hdmi to vga cable
Most of these cables will not support signal from your computer to monitor. See notes associated with cable description at: http://www.amazon.com/A-Sonic-HDMI-HD15-Male-Cable/dp/B001OLCHJ6
If the pic of the cable at that website looks like your cable, I don't believe you will be able to make it work. You still might be able to get signal by using your LCD TV remote and change the 'input' or 'source' button until you see a picture. Good luck!
May 14, 2014 | Dell Studio Slim-Tower Desktop Computer
Can i connect my tv thru a dell optiplex745
Does your TV have a VGA port? If not it most likely has an HDMI port. Does your PC have an HDMI out on the video card? If not then you will need a VGA to HDMI adapter, OR a DVI-D to HDMI adapter, depending on if your GPU output is VGA or DVI-D. Then you will need an HDMI cable to go from the TV to the adapter.
Oct 17, 2013 | Dell OPTIPLEX 745 PC Desktop
I need to connect a Dell Optiplex GX520 PC Desktop to a TV that is non-HDMI Can you assist?
As I see you have two choices to connect your PC to TV.
1. Use VGA to RCA Component Cable
2. Use VGA to Scart Cable - It is hard to find that one.
So if you choose the first option, you have to connect VGA to your computer (it is marked with 9 in the picture below) and RCA end to the TV.
Before that, lower the resolution of the computer and set the frequency of the Video adapter to 50Hz.
Make sure your Video card software initializes the TV.
That's all. Simple as that.
Sep 19, 2011 | Dell OptiPlex GX520 PC Desktop
Dell optliex620 not giving dispaly but starts up
First check for any loose connection Or try to replace vga cable Or if you are using any graphic card on PCI-Express slot try to unplug it and take display from On board graphics.
Aug 23, 2010 | Dell OptiPlex GX620 PC Desktop
Connecting dell mini inspiron with LCD with HDMI cable on both si
You just need a HDMI cable to go from the laptop to the TV. It is refered to as a patch cable. You then go into the TV menu and set it to component or in some cases it will say computer. The VGA on the TV just allows both style interfaces to be connected.
Jun 20, 2010 | Dell Inspiron Mini 10 Notebook
Can not connect my MEDION 8828 MD computor via a HDMI cable to my SAMSUNG ps42q97 hdx 42
use a vga connector. this tv doesn't support pc mode on hdmi. don't forget the 3.5mm stereo jack out fron your sound card to the 3.5mm input(next to vga on tv). you will get 1024x768 res.
Dec 23, 2007 | Computers & Internet
Dell Studio Slim-Tower Desktop Computer   Logo
128 people viewed this question
Alun Cox
