Hobart mig 135 schamatic - Audio Players & Recorders
  • 3,382 Answers
Contact the manufacturer or try an on line search with Google!
Posted on Nov 27, 2014
I need Q1 transistor for 135 hobart welder
The transistor is mounted on the main circuit board, you cannot buy the part from Hobart or Miller, they only sell the complete circuit board.
If you can read any part numbers from the transistor you can purchase the part from a electronic parts supplier.
Jul 13, 2014 | Hobart Handler 140 Mig Welder
Hobart handler 135, the wire starts to feed for about 15 seconds then slows and stops.
Hi:
Don't know how old is your unit but my guess is that your gun's liner is the problem. Have you change it lately? If not, change it. Does your machine just stops feeding the wire or does it shuts down? If it just stop then; is the liner, if it shuts down; then you have a pc board problem.
Oct 29, 2011 | Hobart Handler 140 Mig Welder
I have a 135 hobart and the wire feed only works for a short time then it stops
Lots of MIG/MAG units have a Stich and spot facility, these are indicated by Stitch -------- and spot by .......with a timer control numbered 1-10sec make sure that both are switch to off, anti clockwise, These switches are a bit fragile so be a little carefull with them.
Lets know how you get on,,
KEN
Jan 23, 2010 | Hobart Handler 140 Mig Welder
Hobart handler 135 feed motor for wire doesn't feed wire. motor is ok I tested it with seperate power source. No power to motor from main board or ??????
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill rsheehan@northernsteeldesigns.com
point out what parts to check.and replace.
Rob
Dec 06, 2009 | Hobart Handler 140 Mig Welder
Hobart 135 wire feed sped control problem
you have a resistor down, first check the resistor on the centre pole then those going off to the two other pins
Oct 04, 2009 | Hobart Handler 140 Mig Welder
My Handler 135 mig welder , welds and then cut out will not feed no more .Where could I find a parts for internal parts for Hobart 135? I would love to find a direct location to order this internal parts.
hi if the set cuts out after 10 /15 min on full power the thermal cut out switch is doing its job if it cuts out after 2 or 3 min it is faulty it is a bi metalic switch and is clipped on the main transformer take the wires off it and join up try the set DO NOTweld without it as you will overheat the transformer these little sets only have something like a 20% duty cycle hope this helps merlin v12
Aug 14, 2009 | Hobart Welding Tools
My hobart 135 will not feed wire. I checked for voltage at the drive motor no voltage. The gas still comes on when trigger is pulled but seems that the problem is in the control board?
does it have a reset button? if so it has gone bad, if not there is a fuse or something inside. they protect that circuit against shorting at the working end of the gun. happens ALL the time.
Hawk
Mar 31, 2009 | Hobart Handler 140 Mig Welder
29 people viewed this question
 Grubhead
Grubhead
