Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
AEG Favorit 40660 runs from start to end cycle almost immediately
I have a AEG Favorit 40660 Dishwasher. It does not take water because it runs to the end cycle immediately. It runs through and from the cycle without doing anything, although it sounds as if it function normally.
  • 3 Answers
SOURCE: AEG Favorit 40850
yes its the flood sytem control underneath you might have a leek like i did it was the heater leaking
replaced it and now its running ok its a eay job to replace
Posted on Mar 02, 2008
SOURCE: AEG dishwasher not heating
Had simlar problem. It was the Program module. If yo open the program module you may see a burn track. Resoldering also ddid teh thrick
Posted on Nov 09, 2008
SOURCE: AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Posted on Mar 05, 2009
joe_lishman
  • 192 Answers
SOURCE: Anti flood system triggered Favorit 40660 dishwasher
The problem was solved by opening the machine and finding that the bottom "Y" pipe that has 3 inputs is of extremely poor quality and perforates with pin holes allowing a small amount of water to squirt out. This triggers the anti flood and error status lights flash. The outlet pump is activated and machine does not do anything. You need to replace this hose or like I modified it to work from a 32mm Y plastic junction available from most hardware shops. The wire clamps for this was replaced by "jubilee" screw tight clamps.
I worked on a table and also removed the "Brick" placed at the bottom for balance purposes by cutting the back plastic down with a saw. This made the job very easy...
Posted on Jan 17, 2010
Testimonial: "Thanks, this was the correct answer and solved the problem. "
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
Favorit 44070 3 flashes on end of cycle light. No water loading. Does not start
you need a water valve if the overfill float is not malfunctioning
Aug 27, 2012 | Bosch Dishwashers
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Jan 13, 2010 | AEG 24 in. Favorit 40660i Built-in...
Water not heating. Element replaced with new but still no joy.
The water is heated via a "inductive heater" and not the usual heating elements. This heating device is at the bottom back of the dishwasher and is a cyliderical +/- 15 cm long metal tube. It can easly be removed by the wire clamps at each end. It does have electrical push on connector that just plugs out. If the electrical connections are good I suggest you replace it with a new one (if you can get one).
Mar 23, 2009 | AEG 24 in. Favorit 40660i Built-in...
Dishwasher runs full cycles but the water is cold each time.
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Jan 09, 2009 | AEG 18 in. Favorit F54850 Slim-Line...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Access to flow thru heater
On the 40660 washer this element is in line with the top sprayer arm pipe and is at the back bottom of the washer. Easly reachable by removing the back bottom plate. Has a clamp on each end and a electrical push on connector.
Apr 22, 2008 | AEG 24 in. Favorit 40650 Free-Standing...
No water
If i'm not mistaken.If you pull the unit out,and remove the left side panel,it should be right there.
Nov 25, 2007 | Dishwashers
AEG Favorit 40850
Jul 02, 2007 | AEG 24 in. Favorit 40850 Free-standing...
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
42 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
