Question about Magic Chef 31000 Gas Kitchen Range
The pilot lite gets bigger and hits the thermocouple and lites in 30 seconds as it should, but when it lights it goes out then poofs back on and the flame goes up and down for a few seconds then it does fine. it does this everytime it cycles
  • evamhac Jun 23, 2009
    the burner goes out then poofs almost instantly back on the pilot stays the same .sorry I made it sound like the pilot went out in my question.my fault
    I thought about the presure so I tried it with the burners on and they do fine while the oven is doing the wierd stuff the pilot also stayed steady just the burner itself is acting up for about 10 seconds everytime it relights. thanks for any help
    Genius:
  • 1,478 Answers
From the problem posted, i can assume the problem with your device is just dirt or blockage, i will suggest you clean all the parts of your oven, for easy flow of gas, doing this, will help alot.
Take care.
Posted on Aug 09, 2010
  • 520 Answers
Pick up a can of compressed air. After shutting the gas off to the appliance, blow the compressed air directly into the pilot tube and count to 5. Use a shopvac or vacume cleaner and thoroughly clean the burner and pilot area of any soot or ash that has dropped. Use the can of compressed air to blow across the burner ports as much as possible and then revacum the area. This is a typical gas problem that creates carbon monoxide and most gas companies charge anywhere between $75 to $150 for this service call to do what I just described. After completing this process, turn the gas back on and relight the pilot. Be sure the burner lights. Please maintain a safe distance. After blowing with compressed air the burner and pilot my hesitate to light and cause a flash. Please post me with any updates. Good luck!
Posted on Jun 24, 2009
  • Chris  Jones
    Chris Jones Jun 24, 2009
    In addition to my suggestion before also have the regulator checked. The oven burner uses allot more gas than the top burners and the regulator may be having trouble keeping up with its demand. If that's the case then the regulator will need to be replaced.
    Sergeant:
  • 340 Answers
You have a gas pressure regulator problem unless ya have the proper equipment gas gauges i would call for service. its a safety thing. you don't want to make the News. Tom
Posted on Jun 23, 2009
  • 241 Answers
There are a few possible causes but this is usually caused by a problem with the safetythermocouple
there is usually a thermocouple that is designed to be in the pilot light flame (it normally looks like a small metal cylinder with wires leading away from it)
if the thermocouple isn't hot enough, that indicates that the pilot light has been blown out or something, and it is no longer safe to keep feeding gas to the pilot light (it isn't burning so the gas could fill up a room and cause an explosion)
there are several reasons why the thermocouple might not be registering the temperature
1. the pilot light gas nozzle is partially plugged and so the flame is not as big or as hot as it should be and isn't heating the thermocouple (sometimes you can clean the nozzle with a pipe cleaner or one of these cans of pressurized air)
2. the thermocouple has moved (been bumped or broken) and is no longer in the right place to be heated by the flame
3. the thermocouple wire is broken or unattached at the other end
If it isn't the thermocouple, then it may be the gas valve itself which is usually not repairable and kind of expensive to replace
it could, of course, also be something else
good luck
thank u...........................
Why does burners and pilot forced off after burners are engaged
We get asked this question many times.
If you light your pilot light, hold in the button and then when you release it and the pilot light goes out, generally you need a new thermocouple. Gas repairs can only be undertaken by a qualified gas technician so you can't do this job yourself.
The thermocouple is a safety device that recognises that the pilot has a good flame and is enough to ignite the main burners. The thermocouple open that valve to the burner.
In limited circumstances the thermocouple doesn't need replacing, either the shield that aims the flame to the thermocouple has become dislodged, or the pilot jet is a little blocked by debris. Either way, having the appliance serviced by a qualified gas fitter is the way to go. I am sure you will have seen news stories about explosions caused by gas leaks and faulty appliances.
Jan 18, 2016 | Procom Heating & Cooling
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
It runs out of fuel
sound like pilot lite is not getting thermocouple hot.
check that pilot lite flame is extending out to and touching thermocouple. If not, clean out pilot lite orface and pilot lite gas feed pipe all the way back to the main gas valve if necessary.
If pilot lite flame is touching thermocouple, then replace thermocouple
Jan 22, 2013 | Mr. Heater Big Buddy Heater
When you light the pilot, then put on the burner, it will only burn for 20 - 30 seconds and the pilot light, burner and everything goes off. When you re-lite, the Pilot light will not stay on after you...
Either the thermocouple connection into the gas control valve is loose or the thermocouple needs replacing. Also check the burner and pilot assembly inside the screen area for dust, dirt and insect build up. A clogged pilot can mimic a faulty thermocouple.
Hope this helps you in troubleshooting and solving the problem.
Apr 23, 2011 | Endless Summer 153100 Open Flame Patio...
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
After I lite pilot and release valve, after 30 seconds, pilot goes out. Can not keep pilot lite.
Failed pilot operator or thermocouple not generating enough D.C. current 30 mega volts D.C. Replace thermocouple and see if this takes care of the problem.
Jan 30, 2011 | Dyna-Glo Heating & Cooling
I have a 30 fas the pilot goes out nomadder how
thermocouple may be bad, are you holding for 45 seconds. is the flame touching the thermocouple if all are true thermocouple is bad.
Jan 31, 2010 | Scheu Heating & Cooling
I HAVE MODEL GP30 WALL HEATER. I CAN LITE PILOT BUT WHEN I TURN CONTROL KNOB UP PILOT GOES OUT AND DOES NOT LITE HEATER
The thermocoupler is bad.Replace it,or if you can adjust it to where the thermocoupler is in the pilot flame.You know you have to hold the knob down for about 30 seconds or a minute,don`t you?If the flame will not touch the thermocoupler,it will not stay lit.You can cut a piece of copper tubing,or steel tubing to slidde over the old thermocoupler to make contact with the pilot flame,and it will work,if the thermocoupler is not in to bad of shape.
Oct 17, 2009 | Heating & Cooling
Pilot light does light , but as soon as you release the gas knob it goes out
Hi there. You must continue to hold the knob in for at least 30 seconds before releasing. If the pilot still goes out, the "thermocouple" is bad. It's the little tube in the pilot flame. To replace, remove the main burner assembly/pilot. You can get a thermocouple at any hardware store. Ask questions while you are there.
Thanks
Paul
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
ES 160000 Endless Summer Patio heater won't stay lit
Bad thermocouple that senses the heat from the pilot light. This would be evident if you lite the pilot while holding the button down for about 30 seconds. If the pilot goes out as you release the button on the gas valve replace the thermocouple.
Oct 30, 2008 | Heating & Cooling
Magic Chef 31000 Gas Kitchen Range Logo
111 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
