Question about Microsoft VISTA Computers & Internet
Why use a Hauppauge WinTV-HVR-1250 PCI Express TV Tuner for Windows 1196 reviews
Is a cable provider necessary for premium channels?
McIndia
  • 131 Answers
SOURCE: dual toner card
You will have to install each tv turner software not different folder in the program files folder.
During the installation of the drivers and software you will be prompted with the directory where the software will be installed, on this page you should select say for eg:
for the first tv turner card C:\program files\ hp tv turner
for the second tv turner card say c:\program files \hp tv turner 2
this should be done for every directory mentioned during the installation.
other wise both the card will try to use the same driver and software files, there will be a clash, thus one one tv turner card will be viewed.
Posted on Jan 10, 2008
  • 38 Answers
SOURCE: Windows media center file issue
Some premium channels have DRM locks so that they aren't able to be copied or played on other players, which is most likely what's happening here.
Posted on Jan 31, 2009
SOURCE: WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Posted on Feb 28, 2009
  • 161 Answers
SOURCE: Media center won't connect to analog TV signal
If my memory serves me correctly, you need vista pro. home just isn't powerful enough and not made for it.
Posted on Jun 01, 2009
  • 92 Answers
SOURCE: Dell? Hauppauge WinTV-HVR-1250 TV Tuner
Make sure you have the remote sensor plugged all the way into the connector on the card. Also check your taskbar for the "remote" icon which confirms you have "irblaster32.exe" installed.
Posted on Feb 07, 2010
Dell? Hauppauge WinTV-HVR-1250 TV Tuner "IR Hardware not detected" message during setup
Jan 27, 2010 | Hauppauge WinTV-HVR-1250 MC - White Box...
I have a Hauppauge WinTV-HVR-1600 running windows XP on ATT uverse I can not get the TV Tuner card to pick up any channals I have tried the bundled SW and a thrid party software results were the same. I...
Most likely, all stations in your area have switched to Digital Transmission, and your card can no longer find any. If that is the case, then you need a new card (they are not convertable) sorry.
Aug 19, 2009 | HP Hauppauge WinTV-HVR-1600 NSTC/ATSC Tv...
Compatibility of vista os with hvr-1100
yes it is,
Supported OS: Windows XP Windows XP MCE Windows Vista Windows Vista MCE
Jun 22, 2009 | Hauppauge WinTV-GO PLUS PCI TV Tuner...
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
Feb 24, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No channels after scanning analog cable on Hauppauge 1600
I have exactly the same problem with the very same equipment but I may have found a solution. Try scanning for DVB-T channels and you may find some success. I also recommend printing up the WinTV user manual and reading it. I'm not big on reading manuals but this one actually has a lot of useful info. I will try to fix my setup and let you know if it works. Today it is recording all 6 Star War episodes till 2 am plugged in through the set top box (can't interupt)
Feb 05, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Nov 19, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Nov 10, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Connection Hauppauge WinTV HVR-1250 tuner?
you are not going to get anything once you disconnected from the provider. It is the same thing as just pull the cable from the wall.
you can get TV signal (normal basic-brocasted) by using the roof top antenna, I don't know what kind of antenna will be require after 2/09. when the TV broadcast change to digital signal. but in the mean time, you need a converter box from analog to digital for the TV.
Nobody want to pay the monthly fee. if you have the equipment, you can set up the receiving station from the satellite. then you don't have to pay anything. As far as I know, no body have such equipment. cable company spend millions of dollars to set them up, so you have to pay for it.
Jul 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
TV Tuner for my HP
Hello Matt,
WISH YOU HAPPY MERRY CHIRSTMAS!!!!!!!!
I am Vikram Kumar Thumu from India- Hyderabad. I have seen your message on the issue related to the Tv Tuner card. Since, I work with HP as Technical Support I would like to suggest you on this issue.
Well, the "HP ExpressCard TV Tuner for Windows Vista
(RM436AA#ABA)" supports only for Windows Vista.... and it will not work with Windows XP.
If you are lookng for Windows XP Tv Tuner Card, I recommend you to purchase Hauppauge WinTV-PVR USB2 (EC557AA#ABA). As this one supports for Windows XP but needs Microsoft Windows XP Media Center Edition 2005 .
These are available solution for you at this moment . I hope that this should resolve the issue for you.
If you need any other information please do mail me at thumuvikram@rediffmail.com. I'll be glad to help you.
Once again WISH YOU HAPPY MERRY CHRISTMAS!!!!!!!!!!
Thanks,
Bye...
Dec 26, 2007 | HP Expresscard TV Tuner For Windows Vista...
Computers & Internet Logo
18 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
