Question about Dell Computers & Internet
How to ajust brightness and contrast controls via osd on the st2310f monitor
  • 624 Answers
SOURCE: Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Posted on Jan 31, 2007
  • 238 Answers
SOURCE: brightness and contrast screen in center of monitor and can't remove it
the micro switches on the monitor are getting short which is triggering the menu, try to clean it with a switch cleaner or check if the switches can be replaced, do this only if u r an expert in handling things like this or take some proffessional assistance.
Posted on Dec 15, 2007
  • 11 Answers
SOURCE: always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Posted on Jul 28, 2009
bhagyavichar
  • 414 Answers
SOURCE: ISSUES WITH MONITOR,WITH ERROR MSG AS CONTROLL LOKED AND CONTROLL
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Posted on Oct 24, 2009
pravinbhavsa
  • 348 Answers
SOURCE: The osd main menu and the Brightness and Contrast
there is programmable chip inside the monitor replace it or reprogramme it
Posted on Feb 23, 2010
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
What is OSD ?
OSD means "On-Screen Display. It is a control panel on a television set or computer monitor. It allows you to select viewing options or actually adjust components on the display such as contrast, brightness, vertical and horizntal positions.
For computer monitors, it is usually activated by buttons on the bottom or side of the monitor.
On the television set, it is usually activated either though buttons on the set or via the remote control.
Nov 14, 2012 | Computers & Internet
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
HOW DO I BRIGHTEN UP MY MONITOR SCREEN?
hi,
you can adjust the contrast and brightness of the screen accordingly using the following instructions. Please select the right combination of brightness and contrast according to your desire.
  • Please check out controls in the bottom of your monitor, below the scree. I have provided the image below for your reference.
  • In this the fourth option is OSD menu. Please click on it and you will scoll down to options .
  • you can see options called "brightness and contrast". I have added picture for this too!
9b04c60.jpgOnce you go that page,use the menu to enter! then use the 2nd and 3rd button to adjust the brightness. Now your job is done.Please click on 1st button to exit. If you need more assistance in this, please write back to us. Please rate my solution as helpful!
Apr 02, 2010 | Acer AL1715 17" LCD Monitor
Screen too bright, have just got monitor from e-bay and there are no instructions on use.
Check all the buttons near the ON/OFF button.
One of the buttons will activate the OSD (On Screen Display).
The OSD controls everything about the monitor, including BRIGHTNESS and CONTRAST. Use the other buttons to move between menu-items, and to "select" one of the sub-menus, and to raise/lower settings, and to "exit" from a sub-menu to the main-menu.
Nov 18, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
The menu that controls contrast, brightness ect is stuck on the menu and when i push the number 1 button on he monitor it does nothing but lock the osd. If i hit the down button the contrast will move down...
Try pressing the number 1 again. It should exit the OSD. While the screen is stuck with the OSD. Press the power button (blue) and push to turn it on again.
Hope this helps.
Mar 15, 2009 | ViewSonic VX924 19" LCD Monitor
On the side of the monitor are 6 little buttons. What is the function of each of these buttons.
I found a user guide for a CMV938A that I expect the buttons to be the same.
Here is a link to the manual: CMV938A User Guide
The buttons are described on page 6 of the manual.
1.
Power On/Off button and indicator LED.
Green: Normal.
Orange: Power Saving.
Off: Power Off.
2.
Enter and exit the OSD menu.
3. O/>
•* Quick brightness adjustment and increase contrast/brightness.
•* Move selection right when OSD is displayed.
4. O/<
•* Quick contrast adjustment and decrease contrast/brightness.
•* Move selection left when OSD is displayed.
5 Auto/▼
• *Automatically optimize positions, phase, and clock when OSD is not displayed.
• *Move selection down when OSD is displayed.
6 Turbo/▲ •
*Switch between picture, text and economy modes.
• *Move selection up when OSD is displayed.
Nov 05, 2008 | Computers & Internet
Unable to adjust contrast
http://support.dell.com/support/edocs/monitors/r83546/EN/setup.htm#Using the OSD
"NOTE: When using DVI source, the contrast adjustment is not available"
Dec 06, 2007 | Dell UltraSharp 1905FP 19" LCD Monitor
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
85 people viewed this question
Alun Cox
