Question about Plantronics Voyager PRO Bluetooth Headset
The red light blinks two or three time, but my voyager legend bluetooth is not charging.
I plug it on, but it will not charger.
SOURCE: charging plantronics 520/521
The red light will stay ON while charging and will go OFF when charged. Charging does not take long. Since you have no manual, you turn the headset on by pressing down or toward your head and holding the button down. If it's in your ear already, you'll hear a four-note upward pitch sequence to indicate it's powered on. If it's out of your ear, you'll see a red light, followed by a blue flashing light.
Set your phone into Bluetooth mode and make sure in the menus that Bluetooth is "discoverable" or some such lingo to search for the headset. The pairing code for this headset is 0000 (zeros not O's), so when you set your phone up to pair with the headset and the phone wants a pairing code, enter 0000. After the pairing is completed and Bluetooth is activated on your phone, you should hear a high pitched single tone to indicate the headset is in range and communicating with your phone. If you separate from your phone over about 30 feet or if communication is interrupted with your phone for some reason, there will be a lower pitch single tone, indicating loss of communication. After pairing, you should not have to go through the code sequences or setup again unless your phone is completely reset. You should be able to set your phone to Bluetooth, turn your headset on and hear the four-note sequence, followed by a single high note.
Push the switch up or away from your mouth to step the volume up. Likewise, push the switch down or toward your mouth to lower the volume. I've never turned it down, it's always a little low in volume to me even at max.
Push down or toward your head BRIEFLY to answer or hang up the call. Depending on your phone, you can also activate dialing or voice command by using this same brief push. There is a brief delay between pushing the button and being able to talk on most phones, so you might listen for a volume or noise change before talking.
To turn the headset off, push down or toward your head and hold the button down. You will hear a four-note downward pitch sequence to indicate power-down. If you're looking at the headset, you will see a steady red LED, then it will go off. By the way, a flashing red LED indicates need to recharge. A flashing blue LED indicates the unit is operating correctly.
Remember, battery consumption on your phone is greater with Bluetooth turned on, whether you use the headset or not. Bluetooth units constantly stay in touch with their partners, much like your phone stays in touch with the cell towers. So watch your phone's battery indicator a little more closely until you get used to your talk patterns and general use. Depending on your situation, your phone may not use much more battery than before.
Standby (inactive but ON) time on the headset is very good, and battery shelf life (power OFF) has been good also. These headsets are extremely useful in a car or if you are busy with your hands during calls. Just remember to use your head (pardon the pun) and not take or make calls while doing something dangerous. You wouldn't do that with your corded home phone, would you? The vote is still out, but they do tend to look a little nerdy when worn constantly in public. I hope you get as much benefit from your Bluetooth headset as I have from mine. I thought they were completely Nerdsville before, but I'm a convert now. Good luck.
Mark in Oklahoma
Posted on Aug 28, 2008
SOURCE: Charging does not happen
I took mine back to Best Buy...I think it was a faulty bluetooth...the new one has worked for the past week...good luck!
Posted on Oct 06, 2008
SOURCE: My plantronics Voyager 835 will not turn on, when
Mine is doing the same thing.
Posted on Feb 21, 2011
HDI Headsets
  • 537 Answers
SOURCE: bluetooth wont charge or power on. when charging
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Posted on Oct 04, 2011
HDI Headsets
  • 537 Answers
SOURCE: I bought the plantronics voyager
One thing you can try is to power down and then power the headset back up. The instructions are on the link below for the Plantronics Voyager Pro, particularly the page "Listen To The Voice."
Plantronics Voyager Pro User's Guide
If that doesn't help, then you have a bad processor in the headset. It's still under warranty so contact Plantronics at 800-544-4660 x5 x5538 for warranty service.
Posted on Oct 27, 2011
My headset doesnt turn on, when I plug the charger the red light starts blinking
Could be a combo of low battery and not yet being connected. Charge it overnight and check on it in the morning.
Check out the
Quickstart Guide
Mark
Motorola Support
Dec 31, 2014 | Motorola Mobility H270 Bluetooth Headset
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
I bought voyager pro last month. Today the headset will not charge. Was plugged in all night and it tells me that I have an hour of talk time. I tried plugging into the automobile charger and the red light...
Since you bought it last month I am hoping you have a warranty on the headset. It may be that it is just a bad battery, and the batteries are not replaceable. Sometimes that happens straight out of the package, but not very often. It could have been due to heat or cold damage. Check your connections again, maybe try a different outlet, and is it plugged into the headset correctly?
Jul 05, 2011 | Plantronics Voyager PRO Bluetooth Headset
My voyager pro+ keeps flashing red when charging. However when it is unplugged with charger, it does not work at all. Please kindly help.
If it is flashing red like it is supposed to be charging, and it is not, look at the connections. Are they worn, not connected properly? Make sure that the AC charger is plugged in firmly. If this still fails to charge your bluetooth, it may have to do with the bluetooth itself. If this is still under warranty have it replaced. Try a different outlet or charger to see if that is what is not working.
Jun 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics voyager pro will not charge turn on or anything. do you know the peoblem?
I have seen on some Plantronics Bluetooth headsets that you can perform a system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Jun 18, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a voyager pro+, about a month old, and now the red light does not flash on when I press the 'on' button, or plug the charger into it. Any ideas?
If your are charging through the USB port, and you have put it in wrong at all at any time, the connection will be shot and it will not charge. If this is still under warranty try to see if you can get it replaced.
Dec 31, 2010 | Plantronics Voyager PRO Bluetooth Headset
I am having problems getting my Voyager Pro bluetooth to recharge. I am not getting the solid red light to indicate the unit is charging.
So if it won't charge, it may be that the charger is bad, and you may not have a way of charging it to find out if it is the charger or the battery. If it is the charger you can get a new one, there is a link below to the right part. If it is the headset and it is still under warranty return it to the vendor.
Plantronics 79414-01 AC Adapter
Oct 21, 2010 | Plantronics Voyager PRO Bluetooth Headset
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Plantronics Voyager PRO  Bluetooth Headset Logo
62 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
