Question about Canon imageRUNNER C3200 Copier
Not come in ready stage - Canon imageRUNNER C3200 Copier
    Habit-Forming:
    Scholar:
  • Canon Expert
  • 129 Answers
Check in service mode, * 2 & 8 *, under Copier > display > Dens. Look at the value for each individual color. The normal value would be between zero and one. If you have a color with a value around four or five you have an issue with the toner/starter concentration level for that color. By replacing that color drum unit you will temporarily resolve the issue due to the Developer Assembly being incorporated with the drum unit, which has the correct toner/starter concentration. To resolve this issue replace the Toner Cartridge Drive Assembly, FG6-8999-000, and the corresponding drum unit at the same time.
Posted on May 18, 2014
Can someone guide me on a place to get ready to cook veg food?
Ichef is just what you are looking for. It has a palette of unique ready to cook kits for people who are in the learning stage of cooking.
Apr 26, 2016 | Microwave Ovens
Error 71 / It is not working.
This error indicates that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Nov 22, 2010 | Brother DCP 1400 All-In-One Laser Printer
Machine error 71
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Nov 15, 2010 | Brother IntelliFAX 4100 Laser Fax
IN POWER BOARD FUSE BLOWEN.FOUND MOSFET 2SK 3528 SHORT.NOW WHAT CAN I DO,HELP ME.
The power supplies on this sort of equipment is a safety item. All components that are replaced, and the manufacturers do not supply the components only a complete board, are critical for safety.
If the chopper transister has gone s/circuit, that was caused by an error in the drive waveform. It really is too complicated to explain on a site like this but a blanket change of the driver stage, output stage and control semiconductors will get you somewhere near to a working power supply.
Hope that helps.
Oct 30, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
What is the drive cycle for a 1999 vw jetta
The drive cycle is as follows
For all OBD2 VW's
OBD-II Drive Cycle Stages
The OBD-II Drive Cycle is an eight-stage course, as illustrated in the
chart on page 3. An explanation of each step is provided below.
Stage 1: Cold Start-The ECM determines the presence of a cold start
by comparing the engine coolant temperature to the ambient air
temperature during startup. The engine is considered cold when:
• Engine coolant temperature is below 122°F (50°C).
• Engine coolant and intake air temperatures are within 11°F (6°C) of
each other at startup.
During this period, the O2S heater, misfire, AIR, fuel system, and EVAP
monitors run.
Stage 2: Idle 2½ Minutes-Turn the air conditioning (A/C) and
headlights on to help the misfire monitor-the additional electrical loads
help even out combustion pulses. During this period, the O2S heater,
AIR, EVAP, misfire, and possibly fuel system (if operating in closed loop)
monitors run.
Stage 3: Accelerate-Prior to accelerating, turn off the A/C and
headlights (if possible). Open the throttle halfway until you reach
55 MPH (89 KPH). During acceleration, the misfire, fuel system, and
EVAP monitors run.
Stage 4: Steady State Cruise-During this portion of the cycle, the
O2S, AIR, EGR, EVAP, misfire, and fuel system monitors run.
Stage 5: Decelerate-Gradually coast down without applying the
brakes. Also, on manual transmission vehicles, remain in high gear and
do not press the clutch. During this period, the EGR, EVAP, and fuel
Stage 6: Accelerate-Apply ¾ throttle until reaching 60 MPH (97 KPH).
During acceleration, the misfire, fuel system, and EVAP monitors run.
Stage 7: Steady State Cruise-During this period, the CAT, O2S, AIR,
Stage 8: Decelerate-Gradually coast down without applying the
do not press the clutch. During this portion of the Drive Cycle, the EGR,
EVAP, and fuel system monitors run.
You can try this a couple times, but if it doesn't work you should go to a VW specialty shop like the dealer or a shop that does mostly European cars and they can use the scan tool to force the car through readiness.
Oct 11, 2010 | 1999 Volkswagen New Jetta
Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
Oct 15, 2008 | Xerox DocuColor 12 Color Copier
Machine Error 71, Brother MFC 8440
The problem is in the scanner motor.To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
I hope that this will cancel the error but if not canceled you should call the authorized serviceman to fix your machine.
Sep 26, 2008 | Office Equipment & Supplies
Canon G9 digital camera
There are two stages to the shutter release. The first stage is the focus stage pressed half way down and the second stage is the actual shutter release. Always press the shutter half way to get the camera focused first then press all the way down when the camera is ready to take the shot. Check to see how the settings are with regard to how it focuses (9-point, face recognition, etc). When the camera focuses you should get a green box or multiple green boxes depending on your settings. That tells you the camera is ready to take the picture. Pressing the shutter all the way down at once from the beginning will cause the pause you describe since the camera has to first focus then shoot the picture. Depending on the subject or subjects the camera may take a second or two longer to focus. With good lighting my G9 focuses pretty fast. Hope this helped.
Aug 31, 2008 | Canon PowerShot G9 Digital Camera
Hitachi Ultravision Digital TV dark picture
Looks like
1. A Cold solder in the Video Output stage power supply.
2. A bad Electrolytic Capacitor in the above Video Output stage.
I generally do not waste time in attempting to locate faulty capacitors. There will be only 6-8 pf them in the above stage / section,m and the klot of them would collectivelyt not cost more than 3-4 $ equivalent, in india. Just blindly replace the lot, and the set is ready in 30 mins.
Dunno how much they will cost in your country. Try to look for a 100mfd, 160V Capacitor. Close your eyes and replace. generally does the trick.
Nov 13, 2007 | Hitachi 32UDX10S 32" TV
Canon imageRUNNER C3200 Copier Logo
20 people viewed this question
old marine
old marine
