I have buy Mitsubishi split Ac 1.5 ton model no SRK 18CL-6 ,I confused this unit is legal or unlegal
5 Suggested Answers
chillmaster
  • 104 Answers
SOURCE: oil trap for 2 ton split unit
Pipe size is okay, not that I know any better than the manufacturer, but I would recommend at least two and possibly even three oil traps in the vapor line on the way back up.
Posted on Jun 15, 2008
james3751
  • 614 Answers
SOURCE: Water leakage from internal unit of split AC
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Posted on Jun 07, 2009
heatman101
  • 43501 Answers
SOURCE: Wiring standard for Split AC 1.5 Ton
The factor that you have not included here is the distance from the power panel to the unit...if it is too far then you need to up gauge the wire to compensate for that... that could be why the electrician wanted to go to the 720 ga. wire.
heatman101
Posted on Apr 16, 2010
  • 9 Answers
SOURCE: Hi I have 1.5 ton samsung split AC. the problem is...
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
Posted on May 22, 2010
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
I want to know tonage of ac
12,000 but/ton. If the 101 in your model is their tonnage (101รท12=8.4. its a 8 1/2 ton (5 ton and a 3 1/2 ton combined). That's probably it or very close. I could not look it up cause I don't know the maker of the unit.
Jun 25, 2015 | Mitsubishi Heating & Cooling
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
I am looking to buy a mini split ac/heating 1 ton unit. I want to know how high from the floor does the unit have to be to cool and heat a 10 x 20 room?
Hi, when you buy your split system, the indoor unit will mount on your wall off off the floor a distance that the factory has made it for. With an 8' to 10' ceiling, it would be about 7' off the floor. This all depends on the refrigeration plumbing coming from the outdoor condenser to the indoor unit. It will tell you all of this on the installation kit for this unit, as the plumbing for the freon pipes are already pre-made for a certain height. A 1 ton, (12,000 btu) unit will have no trouble cooling a room of this size, so check with the manufacture on the height it will be.
Shastalaker7
A/C, & Heating Contractor
Jan 04, 2011 | Goodman Heating & Cooling
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
MR. SLIM
that is not the correct m/n normally it wouls be like pu24 36. for every 1 ton the is 12,ooo btus son a PU 24 IS A 2 TON A 36 IS 3 TON A 42 IS A 3.5 TON ETC
Aug 12, 2009 | Heating & Cooling
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
May 01, 2009 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
