Question about Yamaha RX-V663 Receiver
Have no sound and my pcm lights is flashing on my RX V657 reciever
2 Suggested Answers
  • 151 Answers
SOURCE: yamaha rx-v657 zone 2 volume
Go into zone 2 in menu select the source you want then turn up the volume for zone 2,this should work.
hope this helps.
CABLE CUY.
Posted on Jun 30, 2008
Yamaha RX-V657
This will almost certainly be a problem with the power supply, a faulty part. Unless you have experience of repairs to power supplies, due to the high voltages, I suggest you take it to your local authorised Yamaha Repair Centre.
May 09, 2017 | Yamaha RX-V657 Receiver
My problem is conect bose 901v to reciver yahama rx-v657
If you cruise around fixya solutions you will find a number of MY postings for many different receivers.
The difficulty you face is that the RX-V657 lacks the necessary Pre-Outs to feed the Bose 901 Active Equalizer which would feed the necessary dedicated amplifier you will need to route Front Channel programming to the 901's and ONLY the 901's without affecting anything else that flows through the RX.
I have 901's in my multichannel rig alongside 301's and a subwoofer. I know what I'm talking about.
Aug 25, 2011 | Bose 901 VI Main / Stereo Speaker
Hi, i have a jvc rx-5022 vsl reciever. I have just put in a samsung blu ray player and have noticed the reciever picks up dolby, true hd , dts all in 5.1, but when i watch a blu ray with pcm audio 5.1, it...
Check the audio settings on your receiver and make sure they match those of the output on your blue ray. Also make sure you are using the correct inputs/outputs on both
Sep 08, 2017 | JVC RX-6030V Receiver
TV blanks out..."pcm" light flashes on receiver
You need to Bypass the Receivers HDMI port and use HDMI directly to the TV. Your receiver has HDMI version 1.2a and is not 100% effective. Use the optical out from your Xbox to the receiver and all will be well. 1.2a has issues in every receiver on the market. Supposedly 1.3b on the "new" receivers has fixed this issue. Hope this helps
Aug 12, 2009 | Yamaha RX-V663 Receiver
Yamaha rx-v657 zone 2 volume fix
hope this helps.
CABLE CUY.
Jun 29, 2008 | Yamaha Audio Players & Recorders
Volume control
Do you have the volume at -5dB when listening to source 1? That would in most cases be far beyond the receivers capabilities when listening on an average loud recording from a standard source. I would guess that your source has a way to low signal.
However, i assume the answer to the question is this:
There is a way to trim the levels of each source (Input). It can be adjusted -6dB to +6dB.
Select the input you want to adjust. Hit Set Menu on the remote. Then Manual Setup -> Input Menu - > Volume Trim. Adjust up or down. In your case adjust your source 1 to + 6dB and all other inputs to -6dB.
Regards Alex
Mar 02, 2008 | Yamaha RX-V657 Receiver
Dolby digital signal
yes go in main menu of tv audio output and use dobly digital out ok not pcm anlog ok
Feb 03, 2008 | JVC RX-7030V Receiver
Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Jan 19, 2008 | Yamaha RX-V657 Receiver
Unit won't turn on.
My unit turned on and off a few seconds. I try several times and no lights. When disconnecting the power supply of A / C back and does the same.
Dec 29, 2007 | Yamaha RX-V657 Receiver
Yamaha RX-V663 Receiver Logo
46 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
