Question about Plantronics Voyager Legend
My Voyager Legend will not charger. How do I fix this?
The bluetooth sad to charger it. I place it on the charger, but it does not work. No lights at all.
How can I reset my voyager legend headset
www.plantronics.com/us/product/voyager-legend
Jun 11, 2014 | Plantronics Voyager Legend
My Bluetooth needs a charger ,what charger is best to use
Any bluetooth car or home adapter will do, but the specified amp or milliamps (power strength) adapter would be best. My Plantronics M155 came with the 180mA adapter which is very light; quarter amp.
Dec 06, 2013 | Plantronics 510 Voyager Headset - PLN-510...
Charger shows blue light, however after charging for several hours, headset will not turn on. This is a re-furbish headset from eBay however cannot tell if the charger is working or a bad headset, any...
Since you have nothing to compare it to, it's going to be difficult to pin down the culprit. Being a refurbished headset you want to make sure the ac adapter is the right one (the light on Plantronics chargers is green, not blue). You can call them at 800-544-4660 x5 x5538 to get the specs on the charger.
Good luck from Headsets Direct!
Jun 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
My voyager pro+ keeps flashing red when charging. However when it is unplugged with charger, it does not work at all. Please kindly help.
If it is flashing red like it is supposed to be charging, and it is not, look at the connections. Are they worn, not connected properly? Make sure that the AC charger is plugged in firmly. If this still fails to charge your bluetooth, it may have to do with the bluetooth itself. If this is still under warranty have it replaced. Try a different outlet or charger to see if that is what is not working.
Jun 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics voyager pro will not charge turn on or anything. do you know the peoblem?
I have seen on some Plantronics Bluetooth headsets that you can perform a system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Jun 18, 2011 | Plantronics Voyager PRO Bluetooth Headset
Voyager pro / can't turn off, can't re pair, light flashes red blue red blue
Had the same problem. Light just flashed blue and red. I decided to put the headset on the charger while it was flashing and after about 30mins of being left on the charger it started working normally again. Hope this works for you.
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
When you press earpiece to pickup call the phone lift not working and a red light blinks on front left on desk top charging station .It worked fine yesturday - I come in today and it doesn't work. there...
This could be several problems, I am going to give you the one that I believe is the answer. It sounds like it may need to be subscribed again. First here is your user guide:
Plantronics Voyager 510
Plantronics Voyager 510 User's Guide
If that doesn't work, it may be that your headset is bad. If it is you can replace that with this headset:
Plantronics Voyager 510 Replacement Headset
Mar 01, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I put the Voyager pro headset in the car and is turn on, after work, I back to my car and the headset light is out and I go home put in the charger that headset no light on and can turn on again, I try to...
What you probably need to do is turn off, then on, the headset. In today's push button happy society, sometimes we don't always follow the instructions the manufacturer provides. Please follow the instructions carefully in the link below for the Plantronics Voyager Pro+, paying particular attention to "Listen to the Voice" and "Tips." You should be up and running in no time.
Plantronics Voyager Pro+ User's Guide
Oct 27, 2010 | Plantronics Voyager PRO Bluetooth Headset
I am having problems getting my Voyager Pro bluetooth to recharge. I am not getting the solid red light to indicate the unit is charging.
So if it won't charge, it may be that the charger is bad, and you may not have a way of charging it to find out if it is the charger or the battery. If it is the charger you can get a new one, there is a link below to the right part. If it is the headset and it is still under warranty return it to the vendor.
Plantronics 79414-01 AC Adapter
Oct 21, 2010 | Plantronics Voyager PRO Bluetooth Headset
Plantronics Voyager Legend Logo
41 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
