Question about Konica Minolta Office Equipment & Supplies
How to change the time out setting on konica biz hub
  • Konica Minolta Master
  • 6,696 Answers
Posted on Dec 30, 2015
  • 214 Answers
SOURCE: Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Posted on Dec 07, 2007
sir fixalot
  • 146 Answers
SOURCE: pc drum
Replacement of the Photo Conductor Unit
1. Select Tech. Rep. Mode → [Counter] → [Special Parts Counter] → [PC Life].
2. Press the Clear key to clear the counter value.
3. Turn OFF the main power switch.
NOTE
• Clear the PC Life counter before removing the IU.
• After clearing the PC Life counter, be sure to turn OFF the main power switch.
4. Open the Right Door.
5. Remove the IU. Carefully pull on the two green handles
6. Remove four screws (silver) on the sides and disassemble the Photo Conductor from the Developing Unit.
7. Replace the Photo Conductor Unit
8. To reinstall, reverse the order of
removal.
NOTE
• Replace the Toner Filter (Developing
Unit) with a new one at the same
time.
Posted on Jun 06, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
  • 24 Answers
SOURCE: Biz Hub 250 Setting up Scan Button & Resetting password
If you login as administrator via the browser you can edit the scan button settings, (administrator code 12345678)
Posted on Jul 27, 2009
  • 158 Answers
SOURCE: konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
Posted on Oct 31, 2009
Reset a konica minolta 351 biz hub
to what? Code issue , setting?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 16, 2014 | Konica Minolta Office Equipment & Supplies
Biz hub 500 won't print always on scan mode, can't set it to copy mode
Does it copy???? Check the power plug and unplug it
Jan 07, 2014 | Konica Minolta bizhub Office Equipment &...
Error code c1144
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Nov 01, 2012 | Konica Minolta Office Equipment & Supplies
Wanted suitable konica minolta black and white copier to be installed in a school
First for a school you will need to know the volume of copies you are going to use per month.Then go from there, there so many segments.For example 30k to 40k per month would put you in a segment 4 something like a konica Minolta Biz Hub 601 or Biz Hub 750
Sep 07, 2010 | Konica Minolta Bizhub 222 Black and White...
Feb 16, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
43 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
