Question about Apple AirPort Extreme Router
Router will not find printer driver. The printer runs when directly connected to vista machine, but can not hook printer directly to router and have the router find the printer driver.
  • 55 Answers
To do so, you will need a print-server to connect your printer with your router and share the printer locally.Otherwise try to share it as it is connected to your machine.Go in the PRINTER directory,right click on it,sharing then share this printer with a name.Both options work fine but in my opinion try the first one.
Thanks for visiting www.fixya.com
Posted on Jun 23, 2009
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
I cant plot from AutoCad 2006, using My hp
hmmm.. we only have two computers at my work connected to a router. the designjet has a network card going straight to it. i connect to the router wireless and it reads vista. my boss connects to the design jet thru the router as well with a network card rj cable with xp pro. as for our printer it can be connected via router and does work fine but my boss has it directely connected to his computer and i share it off of his system. then we also have a zerox machine connected via router as well. maybe your router is going out? try a new one or a better one and see if that fixes it. it maybe defected or time for a new one.......
if it was working before then maybe its the router.
Jan 07, 2010 | Autodesk AutoCAD 2006
Problem with Vista Business finding my HP all in one printer
your problem is that your missing drivers thats why its not seeing it. you can get the drivers from here if you donot have a disk with the needed drivers
Nov 11, 2009 | HP PSC 1210 All-In-One InkJet Printer
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
HP Printer Continually Drops Off Vista OS
Click on Start -> All Programs -> HP -> HP Update and run this utility. Last month, HP released an update that directly addresses this issue with the PhotoSmart series printers and computers using Vista. You should install any updates listed here, including the connectivity update.
Jul 26, 2009 | HP Photosmart C3180 All-In-One InkJet...
How do I connect a Ricoh Aficio 350 directly to personal computer
I believe the copier only has a tcp/ip port for connection, so you will still need to run it through a router, or if the PC is not on the internet, you can connect the machine directly to the ethernet port on your pc using a 'crossover' cable
You will need to download the Vista driver from Ricoh Here:
|http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x35_45/x35_45en.htm
Mar 23, 2009 | Ricoh Aficio 350e Printer
Want to share 922all in one on xp desktop with laptop using Vista
I have a network running both an XP computer & a Vista computer. What I had to do after connecting them both to the router was make an internet connection with 1 computer, turn on the printer so everything the network was going to share was powered on; then run the network wizard on both computers. Once I did this the computer that the printer is not physically connected to installed the printer driver. Once this entire process was completed we had internet on both computers as well as both computers being able to send jobs to the same printer. Has worked great for over a year. Hope this helps you out.
Mar 16, 2009 | Dell 922 All-In-One InkJet Printer
Having problems hooking my printer up on a home network using a wireless router. I have a desktop computer that has a printer hooked up to it through a USB cable as a local printer. My desktop accesses the...
You are using the wrong cable. Connect the printer to your router with an ETHERNET cable - not USB. Then then printer will have an IP address. Then it should be able to connect without the intermittent off and on that you have been experiencing.
Jan 04, 2009 | HP Photosmart C6280 Printer
Problems adding a vista computer to a mn-700 network
you need to install a driver in your vista which will enable you to print your files.i hope this helps
Dec 29, 2008 | Microsoft MN-700 Wireless Router
HP Printer F4180 will not work on new Vista OS
You could try removing the DSL from the router and running the HP Installer again. Sometimes the filtering can interfere with the router's communication between the computer and the printer.
Otherwise, I would recommend getting one of their printers that has an ethernet port for wired connect (will scan this way; printers won't with USB connect to router) or a wireless 802.11 radio.
Feb 12, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Apple AirPort Extreme Router Logo
123 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
