Question about Lexmark X342n All-In-One Laser Printer
927 Service Fan Stalled - Lexmark X342n All-In-One Laser Printer
2 Suggested Answers
  • 217 Answers
SOURCE: lexmark X646e 927.02 Service fan stalled
This means the fan on the top of the machine, just below the scanner is not working or not working correctly. You will have to replace it.
Posted on Jan 06, 2010
927.03 service fan stalled
hello
This solution was tested for x 204. Get the right cover of the printer. See the fan. Fan connector is located to the card enters the socket. Socket located at the bottom part of the written 4R7. Install this part by removing the 4.7 ohm resistor. The problem is solved.
Sep 24, 2013 | Lexmark T642 Laser Printer
Fan error
This is an indication that a printer fan has stalled. Check the cable connections at J7 on the system board and at the main fan assembly. The main fan runs continuously when the printer is powered on unless the printer is in the Power Saver mode.
Dec 22, 2012 | Lexmark T630 Laser Printer
SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
Jul 02, 2012 | Precor 927 Treadmill
Landice L8 treadmill won't turn on
Check wall outlet for power , then if outlet is good unplug unit remove motor shroud you will see a charcoal or white ceramic fuse check it if open replace blows again immediately you have a shorted lower board. Here is the info Landice they help you with parts and get you in touch with a servicer if you need one.
Landice, Inc.
111 Canfield Avenue
Randolph, New Jersey USA 07869
(800) LANDICE
(973) 927-9010 - FAX: (973) 927-0630
service@landice.com
Apr 24, 2010 | Landice L8 LTD Cardio Trainer Treadmill
NEED TO CONFIGURE THE INTERNET SETTING,
To get your Glo 3G internet settings, you will send SMS activate to 444 using a 3G mobile phone. Save the internet settings in your mobile phone. To get Glo WAP settings, SMS your phone name and model to 927. e.g, to activate Nokia 2630, SMS Nokia 2630 to 927. Save the internet settings in your mobile phone.
Glo manual 3G/3.5G internet settings
Service name: Glo 3G
IP Address: 10.100.98.22
Port: 3130
Username: wap
Password: wap
Access point name (APN): glo3gvideo
Authentication: Normal
Home page: http://cms.gloworld.com
Jan 27, 2010 | Samsung Gravity SGH-T459 Cell Phone
Lexmark X646e 927.02 Service fan stalled
Jan 06, 2010 | Lexmark X646e All-In-One Laser Printer
Printer message reads error 13
Error: 927 Service Fan Stalled
Check the main exhaust fan first. All models of these printers have a main exhaust fan. The main exhaust fan is located on the top of the printer, on the rear left side.
Make sure nothing has fallen down into the main exhaust fan that could be blocking it. There are vent slots/holes in the top cover of the fan, on the left-hand side. Look through these vents/holes.
If there is an item stuck there, see if you can remove it. If not, you will probably need to have a technician remove the top cover unit and extract the jammed item from the fan.
If nothing appears to be blocking the exhaust fan, power off the printer and let it sit powered off for at least a minute.
While the printer is turned off, check to see how it is plugged into the wall. It should be plugged directly into a wall outlet and not through any sort of surge device or power strip. (Power strips and uninterrupted power supplies can cause a low amperage problem in your printer, which could trigger a 927 error.) Even if it has worked on this surge device for months, try connecting the printer directly to the wall. If the printer is already plugged directly into a wall outlet, try it at a different wall outlet.
When the printer has been off for more than a minute, power it on and see if the 927 error returns.
If the 927 error does not return, try printing again. If the printer works as expected, continue using it as you were doing before the error arose. The 927 error may have been just an isolated incident. However, keep an eye on it for the next couple of days to see if the error returns.
If the 927 Fan Stall error continues to return when you power on the printer or when you try to print, the printer will probably require service.
If you are a technician working on a printer that has ONLY one fan installed, check the cable connecting the main fan to the engine/system board. Make sure the connections at the ends have not come loose and that the cable itself is not damaged. The parts that are most likely to need replacing are the main exhaust fan or the printer's engine/system board.
Some printer models also have a second auxiliary cooling fan, sometimes called the cartridge cooling fan. Printers that have this fan are the Optra T614, T616, the Lexmark T622, the T63x series (630, 632, 634) and some models of the Optra S 2420, 2450, 2455, and Se 3455. Note: The second exhaust fan was eliminated on some later models of these S series printers. The auxiliary cooling fan is located on the back of the printer, on the right-hand side.
Check the fan as you checked the main exhaust fan. Look into the vents. Make sure nothing has got stuck in this fan.
Turn the printer off and on again to see if that clears the 927 error first.
If you are a technician working on a printer with this error that has more than one fan installed, you need to establish which fan is causing the problem. You can perform the following checks:
Check the main exhaust fan first as it is usually the cause. If the main fan appears to be fine, check the cable connecting the auxiliary fan to the printer's engine/system board.
Power on the printer. During the warm-up sequence, both of these exhaust fans are supposed to turn. If one fan turns and the other does not, the fan that is not turning is the most likely cause of the problem.
Measure the voltages coming off the engine/system board to those fans. If one particular fan is not getting voltage, the problem lies with the printer's main system/engine board or that particular fan or cable.
The Lexmark T622/622n model printers also have a fan on the printhead unit. This fan is not visible from the outside of the printer, so you will not be able to check it visually. Power the printer off and on. If that does not clear the error and this fan is the cause of the problem, the printer will require service.
If you are a servicer working on this printer model, follow the steps listed above for the auxiliary fan, but adding this third fan to your list of checks for the cause of the 927 error.
Aug 15, 2008 | Lexmark Optra SC 1275 Laser Printer
Lexmark X342n All-In-One Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
