Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
Wireless router connection problems
I used to use my netgear wireless router at my old house with verizion I did not hook it up myself i have moved and now use cox my internet will work plugged in but when I try to set up the wireless router it will not work I think i don't know the network security key
I used to use my netgear wireless router at my house with verizion I did not hook it up myself i now it will work plugged in but when I try to set up the wireless router it will not work I think i don't know the network security key
Posted on Jul 15, 2009
    Scholar:
  • 122 Answers
On the back of the device is a reset button. Hold this in for 15-30 seconds and that will reset the device to factory default. This will make your wireless unsecured, allowing connection. Log into the router and resetup your wireless and you will be able to set your new encryption key.
Posted on Jun 23, 2009
  • 11,896 Answers
That is very possible. I would reset the router by reset switch on back. Also both routers will tend to build up a static charge loosing the connection. You can unplug it for 10 seconds and replug in.
I would also try setting up new home network using automatic settings.
I have several computers in my house, and just purchased a Netgear N600 High Performance Router. All computers easily pickup the signal and connect to the new router. However, one of my computers using a...
you might try moving your computer closer to your router
make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
hope this helps
Jan 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
1 year old Toshiba Laptop will not connect to NETGEAR wgr614v9
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 12, 2010 | NetGear WGR614 Wireless Router
One PC will not connect to Router and therefore Internet.
Sounds to me like the problem is related to the PC hardware. Please check the following in your PC:
- Network card is properly working
- Network cable connecting to the PC is properly working
Sep 21, 2009 | Belkin (F5D5231-4) Router
Netgear Wireless Router Problems
Use the process of elmination, disconnect Vontage, does the problem go away? If no then look at the modem (cable or dsl).
Hint! If you have a cable modem, make sure all cable connections are tight from the outside of the house, to every TV, and from the wall to the cable modem. Use plyers to tighten all of them.
Jan 21, 2009 | NetGear WGT624 Wireless Router
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Does a router or combo need to be connected to computer?
As you already have the modem you only need a router. In all cases the modem connects to the WAN port on the router.
I think your best bet surely would be to go for a wireless router though? Then you wouldnt have to trail ethernet cables all round the house. I'm sure your laptop has a wireless adaptor built in unless it;s very old.
I always use Netgear networking stuff so forgive me posting a link to a nice 54G wireless router :-) :
http://www.amazon.co.uk/Netgear-WGR614UK-Wireless-Cable-Router/dp/B0000C1WO2#moreAboutThisProduct
Dec 27, 2008 | Toshiba PCX 5000 Wireless Cable Modem...
Wireless connection
Hi, I am going crazy! Just moved house and took my Netgear Wireless router with me. However, even though the hard wired base unit works, my wireless laptop can't access the internet - even though a full stregnth signal is there when i browse for wireless connections. Using Vista Home Premium. Help appreciated!
Dec 29, 2007 | NetGear WGR614 Wireless Router
How to install with out the cd?
Are you using XP? You shouldn't need the CD.
http://www.netgear.com/Home/Products/Adapters/GWirelessAdapters/WG111.aspx
Gives you information about the USB adapter.
http://www.netgear.com/Products/RoutersandGateways/GWirelessRouters/WGR614.aspx
That gives you information about your wireless router.
Do you need a manual to set this up? It looks like there are different version of this wireless router. Which one do you have? This can be identified on the package or the unit's bottom label.
Once we know which version you have we can continue.
Dec 11, 2007 | NetGear WGR614 Wireless Router
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
205 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
