Question about Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153
How to fix c610 error - Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153
Kyocera Mita c610 error
C0610 Bitmap (DIMM) problem
There is a problem with the data or
address bus of the bitmap DRAM.
Defective main
PWB.
Replace the main PWB and check for correct
operation.
DIMM installed
incorrectly.
Check if the DIMM is inserted into the socket
on the main PWB correctly.
Defective DIMM. Replace the DIMM and check for correct
operation.
Dec 15, 2014 | Kyocera Office Equipment & Supplies
Error code 1000-0146 on dell d610 even with new hd
format ur harddisk using windows 98 bootable cd in D610 this will definately help u
Jul 07, 2012 | Dell Latitude D610 Notebook
MITA copier DC-2360, error code C610, fuser replaced. How to reset the error ?
IF you have corrected the problem that caused the C610 (broken fixing heater wire), then the error is cleared by turning the machine power switch off then back on.
Jan 07, 2011 | Kyocera Mita Office Equipment & Supplies
Error C610 not printing
Hi all. we had one of these printers and even before it had used of the shipped ink cartridges it was giving the fatal error code C610!! After trying all the fixes, resetting the absorber pad count, (which did work until we tried to use the printer 24 hours laterf, having powered it down. The only good news and guaranteed fix, is to return any canon printer with this error to the retailer. In our case staples in Torquay, who on production of the receipt to prove that it was within warranty, changed it without any fuss at all. Well done Staples UK! as for cannon, you shouldn't be selling kit with such a known and serious fault. we have replaced the Cannon with a Kodak ESP 5250 - it doesn't have a paper cassette, but its faster, the print quality is better, it was about the same cost and ink is far cheaper! oh and installation straight to wireless is great, so well done Kodak.
Dec 22, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Kyocera KM-1510 error c610
Broken fixing heater wire
Jul 10, 2009 | Kyocera KM-1510 Copier
No sound from dell latitude c610 notebook computer
You usually fix the cood11ba problem reinstalling the sound driver for this laptop.
Sound drivers for this model can be downloaded entering model number on page below and following instructions:
Dell Drivers and Downloads
May 18, 2009 | Dell Latitude C610 Notebook
Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153 Logo
14 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
