Question about Sewing Machines
How to thread a gemsy serger old model rxm5da?
2 Suggested Answers
  • 9 Answers
SOURCE: threading machine
Visit us at www.janomestuff.com to avail for a new manual for only $10.00
Posted on Sep 18, 2009
My serger is still not working properly trhread still breaking lower and upper
Generally, thread breakage is due to incorrect threading, threaded out of order, tension too tight, or the threads are looping or hanging up on their way through the thread path. Be sure to remove ALL the threads from the machine and RAISE the presser foot while threading. Give each thread an extra little tug when going through the thread tensioners to make sure they are seated all the way. Consult the owner's manual to verify the thread paths are correct and the threads are threaded in the specified order. (If not threaded in the proper order, the serger will most likely never work satisfactorily.) Perhaps changing thread brands will help--and avoid old or bargain bin threads. Set the tension guides to the midway point between high & low numbers before testing.
If there continue to be issues, the timing may be off or a looper may be bent. Take it for service.
Make It Handmade How to Thread Your Serger Out of Order
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH&submit=y
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
serger thread keeps breaking help
Mar 19, 2016 | Sewing Machines
Threading diagram for rimoldi 3 thread serger model 627
Rimoldi Serger Manual PDF And Ebook Files - DocsFiles
docsfiles.com/pdf_rimoldi_serger_manual.html
Rimoldi Serger Manual PDF Files, Manual For Rimoldi Serger honda nx 250 service ... Manual FREE Parts Crochet - Loopers RIMOLDI 8 8 Kl 327 , 527 , 627 , F27 ...Rimoldi Serger Manual Rimoldi B.27.77 Industrial Serger, 3-Thread, Nov 26, ...
rimoldi 329 threading diagram Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your rimoldi 329 threading diagram question. ... Rimoldi orion 627... rimoldi overlocker how to thread Which Model Rimoldi? ... Level 3 Expert.
rimoldi pdf - P(1) - Docs-Engine.com
Feb 05, 2016 | Sewing Machines
USE MANUAL FOR GEMSY SERGER MODEL RXM-5D-A
call Miami Gemsy co in Florida or email them at gemsyusa@hotmail.com or call at 305-883-0829 or 786-863-7187
Aug 02, 2012 | Sewing Machines
I need a manual
try these websites
sew usa
sewing manuals.com
ebay
Jul 27, 2010 | Singer Tiny Serger TS380
My serger will only sew a few inches, then the thread on the lower looper breaks. I have checked threading, rethreaded many times.
Been there, done that. Old serger almost went out the window more than once.
Raise the thread antenna and loopers to their highest positions.
Set the tensions to zero. If your serger has auto-tension, raise the presser foot as this also opens the tensions.
Begin threading from the right as indicated in your manual or on the door of the serger.
If this continues, the serger may need to be serviced as the timing could be the problem.
Ask before leaving the serger as the service cost usually starts around $100.
I finally gave in and bought a Babylock with instant jet-air threading.
Apr 01, 2010 | White Sewing Speedylock 1600 Mechanical...
I dont know how to thread this serger. i dont
Have you opened the front of the serger to see if there is a threading guide.
Basically:
Lift the thread antenna to it's highest position.
Lift the presser foot and set the tensions to zero.
Turn the handwheel so the loopers are at their highest point.
Begin with the upper looper (first thread cone on the right/ end of looper is pointing toward the presser foot). .
Second spool is for the lower looper (end of looper is pointing away from the presser foot).
Third spool, right needle; fourth spool, left needle.
Be careful that the threads do not cross during the threading of the loopers.Follow all the guides, taking the thread under the presser foot and to the left side of the serger.
Set the tensions back to 3 - 6 and lower the presser foot. Sew a few inches and if the threads knit into a chain, you can then do a test sew with fabric.
Simplicity's Simply The Best Sewing Book has good information with regard to using a serger that you may find beneficial.
Feb 24, 2010 | Sewing Machines
Threading rl-635 serger--wife is trying to tread this machine and the lower something or other doesn't work. Cannot find a manual, and the tape they sent with the machine is all messed up.
Sergers can be a bear! One miscue and - well you know. My old serger was threatened more than once.
Are the instructions for this model printed on the inside of the door or on the machine?
Note every guide and make sure none are missed.
Raise the thread antenna to it's highest position.
Raise the presser foot and turn the tensions to zero.
Start threading with the upper looper, making sure the loopers are not crossed.
The upper looper is the one that appears to be taking the thread toward the needles.
Make sure the threads do not cross as you then thread the lower looper (this one appears to be taking the thread away from the needles).
Lastly - thread the needles; right needle first.
Take the ends of the thread under the presser foot and toward the left side of the presser foot.
Lower the presser foot and set the tensions back to 3 - 6.
Stitch a chain of thread before stitching fabric.
If this works, and I sincerely hope it does, never let the serger run out of thread.
Snip the thread near the cone and tie off snugly with the new thread.
Lift the presser foot and open the tensions and stitch or gently pull the thread toward the back of the serger. The knots should clear all but the eye of the needles - stop, cut before the knot reaches the eyes
Feb 22, 2010 | Riccar Sewing Machines
Threading illustrations too small
You might take a look on ebay item 160362974035
May 29, 2009 | Baby Lock Eclipse Serger
Threading machine
Mar 28, 2009 | Sewing Machines
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
