Question about Kyocera FS-1035MFP
Kyocera fs-1035mfp/dp showing c3100 on the screen
Why is kyocera fs-1035mfp/dp showing c3100 on the screen
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
  • 46 Answers
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
Posted on Jun 12, 2009
  • 241 Answers
SOURCE: kyocera fs-3900dn showing 7410:0024216 error code
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Posted on Jun 09, 2010
  • 10406 Answers
SOURCE: Kyocera FS-4000DN is showing install
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Posted on Jan 19, 2011
My kyocera FS-1035 is displaying error message: The developer unit is not installed. What can I do, it won't allow me to enter the menu
Hello, you need to check that the developer is installed properly. Also check that all the contacts are clean.
How did this error happened?
Nov 25, 2016 | Kyocera FS-1035MFP Printer
How to repair kyocera 1024mfp error code c3100
http://www.fixya.com/support/t6140540-also_need_service#solution-section
Feb 14, 2015 | Kyocera Office Equipment & Supplies
How kyocera laser mfpsenses toner bin and powder
toner and developer are different the developer is usaly by the drum check too see if its in the machine or installed correctly
Jul 27, 2014 | Kyocera FS-1035MFP
Why does the display show no suitable paper
Check the original paper size and the paper size in cassete
Jul 18, 2014 | Kyocera FS-1035MFP Printer
Reparation error c3100 for kyocera fs-3010 mfp
Scanner carriage error
The home position is not correct when the power is turned on, at the end of a reading process of the table and document processor.
Apr 30, 2014 | Kyocera "FS-3040MFP Printer, Copier, &...
Set up a Kyocera copier
you have to make sure the mfp is set up on the local area network, then set up the smtp information in the command center. See THIS LINK for instructions or consult kyocera support site or your install disk for users manuals. it is very similar to setting up outlook.
Dec 30, 2013 | Kyocera FS-1035MFP
C3100 toner waste
replace the waste toner bottle. your new toner should come with spares
Sep 16, 2013 | Kyocera FS-1035MFP
Error C3100
This code means machine's scanner home possition error. Try to check scanner home possition sensor if fixed in its possition. if not try to check scanner lamp unit movement .
Jan 20, 2013 | Kyocera FS-1035MFP
Kyocera FS-1035MFP Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
