Question about General Electric H1200 Digital Camera
I'm getting a lens error whenever I turn it on. Why is that?
I was trying to turn on the camera when it gave me a lens error. Not sure what this means, though.
Whenever I switch the camera on, I get the error message "Access Turn the power off and on again". Lens does not collapse and remains extended. Cannot take pictures. This happened after the...
Unfortunately, many cameras that fall prey to lens error problems (Access Error on Sony's) can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jul 03, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
I have a canon powershot SD13001S and whenever i turn it on it says lens error how do i get it to work?
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed air into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Avoid applying pressure to the lens and surrounding area:
1) Do not touch Lens while shooting. 2) Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera OFF and then on again then your device need to be repaired.
Rating the solution is highly appriciated...Good Luck.
Aug 29, 2010 | Cameras
Lens Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 28, 2010 | Canon PowerShot SD1000 Digital Camera
Lens wont extend, lens error restart camera
My wife's Canon SD200 got stuck with an open lens and the E18 error. I opened the case and wiggled things and still nothing. Then, I turned the camera on and started tapping the edge of the lens casing with the magnifying glass I'd been using (need the battery and memory chip in place and make sure you've transferred pictures to your computer before trying this). Voila! The lens closed. But, of course, it wouldn't open and still gave the E18 error. Well, one good tap deserved another and Voila! again. It opened. After a few more iterations - and cleaning the lens casing each time, it was back to normal. The trick is the timing of the tapping. Just after turning on the power to the camera start tapping on the lens casing - not hard - just a light tapping. And don't tap on the glass lens itself -- you don't want to really break it.
May 15, 2009 | Canon PowerShot SD600 Digital Camera
''lens error restart camera.''
Was the camera dropped or has it been exposed to sand dirt etc?
Nov 13, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
3. Turn camera on
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
E 18 Message
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 21, 2008 | Canon PowerShot S2 IS Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Pentax Optio 60 LENS
The same thing happened with my camera, I gave it to a freind for her husband to look at it. He said when turning on face the lens side down (to the ground) when turning off hold lens side up right (to the sky). this worked for mine. I don't know if he did anything else to it but when I zoomed I got lens error. I did what he said and it took several tries but it did work... please post if this helps you.
Dec 13, 2007 | Pentax Optio 60 Digital Camera
General Electric H1200 Digital Camera Logo
Top General Electric Cameras Experts
Freddy
Are you a General Electric Camera Expert? Answer questions, earn points and help others
