Question about SkyScan 34202 Clock Radio
How do I turn the alarm on or off - SkyScan 34202 Clock Radio
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
How to turn off the alarm on a sylvania imode sip478
If this is for turning the alarm completely then I also had the same problem. The directions in the manual are not clear but all you have to do is quickly press either Alarm 1 or Alarm 2 (depending on which one you are turning off) twice and the alarm will be deactivated.
Aug 21, 2012 | Curtis iMode Digital AM/FM Stereo Radio...
Have a bluehat time space projection alarm clock and the alarm won't turn off. Always goes to a snooze mode. Need help making it turn off. Instruction Manuel offers no help.
To turn off the alarm I pressed the alarm set button. While in the alarm set mode press the up button to turn the alarm and snooze off and on. That's what worked for us. Neat clock, the instructions are just a little lacking:)
Jan 19, 2012 | Toys
Alarm set
this is a factory alarm, the problem is the alarm is active, you will need to use the door locks to turn alarm off, insert key in driversdoor and lock and then unlock door this will turn alarm off, if that doesnt work then use pass/side door, the lock has a built in switch that knows when the door is locked or opened, the driversdoor may have a bad switch so inturn the computer thinks the door was forced opened without key and it is turning alarm on, so again use the key to unlock door try the pass/side if driversdoor doesnt work. good day
Nov 24, 2011 | 1998 Plymouth Voyager
How do I keep the alarm from flashing? I just want to turn off both alarms. Timex nature sounds with cd T621T, Thank you
Hello, To turn off the alarms follow these steps -
  1. After the alarm sounds, press the "F" alarm off/reset button to shut the alarm off but retain the 7-5-2 alarm settings.
  2. If you want to turn the alarms completely off and cancel the 7-5-2 settings, press the "alarm" button so that the "alarm" indicator is no longer visible. As long as you can see the word "alarm" on the display the alarms will continue to go off according to your 7-5-2 alarm settings.
Regards, Tony
Mar 24, 2011 | Timex Nature Sounds LED Clock Radio
Alarm stopped working
sounds like the system is in valet mode.
locate a switch under dash if a toggle switch is found then turn on key and flip switch. turn key off if led is off try alarm.
If a push button switch is found then turn ignition on and press the switch for 10 seconds, then turn key off iff led is off try alarm.
Sep 22, 2009 | Vehicle Parts & Accessories
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 | Watches
Unwanted alarm
using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
SkyScan 34202 Clock Radio Logo
21 people viewed this question
Top SkyScan Audio Players & Recorders Experts
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Tom Chichester
Are you a SkyScan Audio Player and Recorder Expert? Answer questions, earn points and help others
