Question about Measuring Tools & Sensors
How to fix a surging motor briggs & stratton 20.5hp
Craftsman lawn tractor
youcandoit2
  • 11 Answers
SOURCE: How do I clean the flywheel on my Craftsman/
What is on the flywheel?
You can wash it off with water spray or clean with soapy water. Let engine cool down before cleaning it. Let it dry before running the engine.
Posted on Aug 03, 2009
  • 17 Answers
SOURCE: craftsman 19.5 lawn tractor w/briggs & stratton keeps flooding
This could be a number or items from no spark to a faulty carburetor, a plugged up air filter, valves out of adjustment, poor gas, faulty spark plug.
First, see if your getting spark, how about taking the wire off a plug(s) and holding it about 1/8" or so away from the plug with some masking tape while you crank the engine. You should be able to see the spark jumping the gap, it helps if it is not too light outside. If you attempt to do this with your hands, you will get a spark jolt, it hurts, so use the tape and remember, the engine could start so proceed with caution.
If you have no spark there, then you ignition or magneto is faulty. This would be unlikely in the broader scope of things. You will likely get spark. Make sure the plug is clean, take it out and inspect. If it is covered in gunk well clean it. It will smell like raw gas but you already know that. Change the plug if in doubt.
Remove and clean and replace the air filter.
If you have spark, and a clean filter it is likely a carburetor problem, Depending on the carb, it could be the choke is faulty or, as per the below.
Depending on what model you have there is a float assembly in the carburetor that stops the fuel from flooding the carb and air intake. The gas tank is higher then the carb right, so if you dont have a mechanism for stopping the fuel from leaking out the hole that goes into the engine, it will all leak out right, as into the fresh air intake because its easier than going into the engine. So, there is a miniature float assembly, sort of like your bathroom toilet float to stop the water. Well there is a small wedge type needle that seats into a hole and it is attached to a float. As the gas rises in the bowl, it pushes up the float, sealing the gas into a chamber, as you use more gas, the float lowers and more gas goes in. So ,there is dirt jammed into the float bowl sealing needle, just a little, thats all it takes. So, shut off the gas somehow, hopefully you have a valve, or squeeze the rubber line, then undo the float chamber, its one nut on the bottom. Clean carefully. The needle, little spring and float assembly are delicate. Also, the needle could be worn from engine vibration, so it may need a new needle. It would help if you described the engine and carb though.
I posted that as a solution to another problem, but yours may also be the valves need adjusting. Depending on the amount of hours, say over 200, then the valves timing will likely be off a bit. Check the clearances with a feeler gauge, it is not as difficult as it seems. Check your Owners manual for the clearance at top dead center. TDC is when you take the plug out and watch the piston arrive at the top of the cylinder through the spark plug hole when you are turning the engine over (do this by hand, battery off. Make the adjustments with the valve cover off. Follow the instructions.
Hope some of this helps.
Posted on Sep 21, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 454 Answers
SOURCE: Briggs and stratton lawn tractor. misses under load after warm up
check air filter, may be very dirty causing it to run too rich
Posted on Jul 30, 2010
HansPP
  • 2510 Answers
SOURCE: I have a Craftsman lawn
That sounds like a fuel supply problem, anywhere from the tank into the carb. Check that the tank is clean and that all the fuel lines and passages are clear. You can confirm this by spraying quick start into the intake and seeing if the engine will continue running while the quick start is sprayed into the engine.
Posted on Jun 25, 2011
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor ยท Operation Manual.โ€ŽCraftsman Lawn Mower manuals - โ€ŽCraftsman 247.370310 - โ€ŽCraftsman 247.37030
Aug 02, 2015 | Craftsman Garden
Tip
2008 Craftsman lawn tractor
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Jul 30, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
My Craftsman 42" lawn tractor
I would suggest checking your owner's manual. There is a leveling process and my Craftsman wasn't leveled at the factory. Once I leveled mine, it cut fine. If you can't find it in your manual, google leveling craftsman mower deck.
May 14, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Need owners manuel
i need to know oil reference for 19.5 hp craftsman lawn tractor
May 23, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do I change the drive belt on a 17 horse Craftsman lawn tracton number 917.252531.
Page 24 of the manual:
http://www.managemylife.com/mmh/owner_manuals/23145/CRAFTSMAN-Lawn,-Tractor-L0909236?brand_name_search=917252531+CRAFTSMAN
May 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Measuring Tools & Sensors Logo
47 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
