Question about Generic Intex 26 x 52" Ultra Frame Metal-Walled Swimming Pool
Bought new pool and the ladder has the wrong legs one set of steps is inverted and dangerous to climb. Pool also needs a tubing from pool to filter machine. Just bought 26" Intex on Walmart.com
When I assembled the pool the ladder had one set of steps that work fine but the back side is inverted due to the wrong poles being sent with pool. Also pool needs tubing from pool to filter machine. How do I get these missing pieces?
  • 1,631 Answers
Posted on Apr 05, 2015
  • 44 Answers
Sounds like a warranty calm back to manufacturer...
Posted on Sep 01, 2014
Closing inground pool
Question:
How do I close my pool for the season?
by Osko Pool n Spa Information
By following the provided instructions, you will be able to professionally close your pool for the winter season. Additionally, you will protect it from winters abuse and make opening it next season...simple.
Required Tools
a) Standard Screw Driver
b) Phillips Screw Driver
c) Ratchet Set
e) Plumber Pliers
f) Sump Pump
g) Extension Cord
h) Garden Hose
i) Five Gallon Bucket
j) Air Pump or Shop Vac
k) Pool Vac & Accessories
Required Chemicals
a) Pool Shock
b) Algecide
c) Chlorinating Tablets
Required Accessories
a) Winter Cover
b) Pool Pillows or Inner-tubes
c) Chlorine Float Dispenser
d) Water Bags (for ingrounds only)
Step One - Debris & Chemicals
Remove any debris from pool water by use of a leaf rake attachment.
Add the appropriate amount of shock treatment to the pool water, as prescribed on the packaging.
Add the appropriate amount of algecide to the pool water, as prescribed on the packaging.
Run your filter for the appropriate time to circulate all water once.
(see your filter documentation for your size pool)
Install your floating Dispenser and winterizing tablets.
Step Two - Vacuum & Water Level
Vacuum your pool while setting your filter to the "back wash" or "waste" setting.
(this will help lower your water level)
After vacuuming, install the sump pump and drain pool to about 6 inches below your thru-the-wall skimmer.
Step Three - Parts Dissassembly & Cleaning
Disconnect all ladders, filter systems, hoses, solar reels and/or other accessories.
Using standard household cleansers, thoroughly clean all ladders, solar reels and/or other accessories.
Dissassemble filtration system.
Remove sand, cartridge or DE powder from your filtration tank.
Thoroughly clean all filter system parts.
Allow all items to dry.
Store all items in an area that will not be subject to freezing temperatures.
Step Four - Pillow & Cover Installation
Inflate all pool pillows or inner-tubes.
Install one pillow for every 15' of linear water surface.
(example: a 15' x 30' would require at least two pillows)
Tie pillows to pool area via nylon rope and place equally with respects to pool walls and each other.
(this is extremely important! This prevents freeze damage)
Install winter cover as prescribed by the covers manufacturer.
Step Five - Winter Tips
During the winter months, remove any excess snow from the winter cover.
(If you have a solid cover, this will prevent excessive weight form tearing you cover)
(If you have a mesh cover, this will prevent excessive water build up)
Hey, Your Finished! Congratulations, you just saved money while doing a professional job
Nov 11, 2013 | Hayward SAND FILTER, PRO SERIES
My Kreepy has a Starfish seal on it. It is being used in a pebble tec pool. I bought it new less than a year ago. Here are my problems...The Kreepy is getting stuck by my stairs (they are more like...
If the cleaner is getting stuck on objects (steps, ladder, corners, benches, etc), you need to remove the dive float restrictor and install a wall climb adjuster. It is part number K12065. Anyone that sells Pentair products should have one. This will keep your pool cleaner from becoming stuck. It might also help with the seal problem, but that is most likely something caught in the flapper. Check to be sure that the pool cleaners getting proper flow and that the flapper is clear of debris.
Jul 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
My wife and i bought a 16 by 48 in. ultra frame intex pool. we had profesionals level the ground, we have a sandy base, and after filling our pool with water and the legs settled, the pool is approx. 2 in....
There won't be any structural problems and you will notice the difference more than anyone else. If you redo the pool next year it will help to set each leg on a patio brick so it won't settle.
May 10, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
Kreepy bull shark gets stuck in the corners and stains (dark brown/black) the pool where it is stuck.
There are several things that you can do to prevent these pool cleaners from sticking at steps and corners. First, your return line water flow might be positioned incorrectly to force the cleaner toward the corners. Check for this and use the eyeball diverter valve to redirect the water flow if necessary. Make sure that your automatic regulator valve is installed properly and free of debris. Make sure that you have proper hose balance (the cleaner should set at a 45 degree angle to the pool bottom). Adjust the hose weights if necessary. You may need to add a wall climb restrictor or a ladder guard. If none of these correct the problem, consider adding the Thruster, which aids in random pattern coverage by automatically repositioning the hose to help free the cleaner from obstacles.
Apr 14, 2011 | Universal Kreepy Krauly In-Ground Pool...
I put the eyeball diverter on my pool and the cleaner runs up to it and the hose hangs on it. I keep my hose laying out strait when not in use. It does seem to stay on the sides also.
If the eyeball diverter is not working, you might need to install a wall climb adjuster (Part #K12065). This will keep the automatic pool cleaner on the pool's floor and walls and away from pool obstructions. Make sure the narrow end of the wall climb adjuster points down to the drive tubes.
Aug 23, 2010 | Universal Kreepy Krauly In-Ground Pool...
Aquavac Tiger shark won't operate
The power supply powers on even when it doesn't output any voltage, so it's kind of misleading. You should have the power supply checked or you can do it yourself if you have a multi-meter, by measuring the output and making sure there is 24V.
Jul 17, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Low pressure of 5 on our pool pump. Replaced sand, replaced filter O ring, no air leaks (no bubbles, no air in pump), and no clog in the filter line (bought a device to clear out any potential clogs, and...
Sounds like your impeller is clogged, you might be able to remove the pump basket and feel inside the impeller to see it it's impacted with debris. You may have to pull apart the pump to clean it thoroughly.
Jul 10, 2010 | Pool & Spa
We bought new feet for the navigator and put them on and it won't climb the walls we tried to to change the seetings to number 3 and it still won't climb.
you'll need to increase the suction so it will climb. If it used to climb before and now it won't, even with new feet, it may be a bearing problem with either the turbine or the A-frames. You may have to get a turbine kit with a-frames to make it work like new again.
Jul 01, 2010 | Hayward Navigator Pool Cleaner
Ref: Sta-Rite Max-E 400. Pool temp is about 75
Your temp sensor has gone bad and will need to be replaced. It's a small tube that slides into the water manifold and you can follow the wires back to the board. Just unplug and set a new one in place.
May 12, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Generic Intex 26 x 52" Ultra Frame Metal-Walled Swimming Pool Logo
566 people viewed this question
Top Generic Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Generic Pool and Spa Expert? Answer questions, earn points and help others
