Question about Big Button Lands Phones
How do you turn the volume button down on the HSV708
One of my Motorola T9500 keeps vibrating upon being turned on, and no display. Pressing any button does not result in any response. It has never been in contact with water. Please help. Thanks.
Please make a hard reset . 1.In order to turn off the phone hold down the Power button for a short while.
2.Afterwards press and hold the Volume Down button for about 2-3 seconds.
3.While still holding these keys press the Power Button for a few seconds and release all buttons.
4.In this step choose option Recovery by using to navigate Volume Down, and to confirm Volume Up.
5.
Hold down the Volume Up for a while when an Android Logo appears on the screen.
6.While still holding the Volume Up button, press and release the Power button
7.Press Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm
8.Select "Yes--delete all user data". Use Volume Down button to scroll and Power button to select
9.To restart the phone, select "reboot system now.
10.Success! The hard reset has just been performed
MOTOROLA XT1021 Moto How to Hard Reset my phone HardReset info
Dec 01, 2016 | Motorola Cell Phones
There is no sound when I receive phone calls?
Perhaps you have accidentally pushed the volume button and turned down the sound.
Many of the cell phones have a volume button on the side, and whilst holding the cell phone with your hand, your hand pressed on the volume button and holds it down accidentally.
Find the volume button and see if it is turned down.
Remember, most of these have one button for both the incoming call volume and also the speaking and listening volume all at once.
You have to adjust both volumes with the same button depending on what your phone it doing when you press it.
God bless your efforts,.
May 16, 2016 | RIM BlackBerry Cell Phones
How do I turn down the volume on DVD portable Sylvania without remote
To turn the volume hold down the play/pause button
To turn the volume down hold down the stop button
Aug 31, 2014 | Sylvania SDVD1030-RED 10-Inch Portable DVD...
I have a uniden phone and for some reason it has become very loud and there isn't anyway i see to turn down the volume
The arrow near the center button has an Up Down feature. Press above the center button to increase volume and press the ring below the center to lower the volume.
Feb 26, 2014 | Uniden Cordless Phone
HSV708 BATTERY ONLY CHARGING 70%
Where can I get a charger for my phone. Hsv708 phone
Feb 24, 2014 | Big Button Lands Phones
MIA Phone Model HSV708
Volume and audio voice is much too loud, is there a way of changing this. I think I have bought the wrong phone
Jun 15, 2013 | Computers & Internet
Television volume down button sticks.
spray windex or 409 on the button n press it as you spray it n around the button. Loosen the grime in and around the button.
Sep 24, 2012 | Magnavox 32MF369BF7 32 in. LCD TV
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
The up volume button is broken and I cant' turn it up anymore
volume is next to the down volume. maybe the button broke off and you lost it.
May 22, 2010 | SanDisk Sansa Clip MP3 Player
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Lands Phones Logo
16 people viewed this question
Top Big Button Lands Phones Experts
richie46
ray gallant
Tom Chichester
Are you a Big Button Lands Phone Expert? Answer questions, earn points and help others
