Question about Franke /Kindred KIND KCFS30B/10 Designer Series Stainless Steel Apron Sink
My pop up feature is not working. Why does my Franke strainer sink plug pushed in manually, not hold water?
3 Suggested Answers
  • 81 Answers
SOURCE: I have a white Franke fireclay sink. We also have
The best product I have found to remove water spots is a product called A-maz water stain remover in a 14 oz tub. There is no magic "wipe on,wipe off" product that I have found. Initially it is a little labor intensive but this is amazing stuff and can return your sink to its original luster.
This company also make a sealer but I have not tried it. A couple of alternatives might be Rain-X or Maguires auto wax. The concept here is to put a barrier down that will seal the pores of the sink and make it easier next time to remove the spots. My favorite is Maguires about every 3 months. I have provided a link below to the A-maz web site where you can find a distributor nearest you.
http://www.a-maz.com/
Posted on Jun 02, 2010
SOURCE: I installed a black granite
This is all wrong! You can't use plumbers putty on a granite sink! You're supposed to use a sink and tub caulk which unfortunately is a real pain to get seal. Read the directions on a granite sink... they say DO NOT USE PLUMBERS PUTTY!
Posted on May 12, 2012
Franke plug seal problem
Adjust the clip underneath the sink to a different hole on the rod so it will tighten more when used.
Feb 19, 2014 | Franke Home
What is the difference between Franke 900 and Franke 900SN strainer
The 900 is chrome the 900SN is Satin Nickle finins
Sep 23, 2012 | Plumbing
Hi When I push down the Franke Strainer Basket in order to fill the sink basin, it appears to leak in the cabinets below. With out pushing down the strainer basket whilst tap is running there is no...
More than likely it's leaking from where the body meets the sink. U might need to pull it apart, clean it up, and re apply plumbers putty to the sink and re apply the body. If you are doing this I would recommend buying a new basket assembly from the hardwear store. Just makes more sence than re using the old one. That is enles it's new. Hope this helps
Mar 29, 2011 | Franke 900SN Strainer Basket: Satin Nickel
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
I Have a FRANKE Fireclay white Farm sink only 90
E-mail the manufacturer from this page.
http://www.frankekitchensinks.com/link_to_us.htm
Sep 04, 2009 | Franke Plumbing
What is the difference between franke sink and
It's what some contractor likes. If you find a sink that you like, buy it. ANY decent contractor can easily and successfully mount ANY sink.
Aug 09, 2009 | Moen 22119 - Commercial Stainless Steel...
Insulation falling off bottom of sink
This insulation is important as a sound reducer so I would definitely glue it back into place. Go to any home depot, lowes, or other hardware store and get construction adhesive, the tacky kind will work best for your purpose. Then just put a thin coat directly on the bottom of the sink and stick your rubber back in place.
May 27, 2009 | Franke CPX-110 Compact Undermount...
Rust around the drain in the larger of the two sinks
You will need to reset the basket strainer using plumbers putty. Is there a garbage disposal installed? You will need to remove it to get to the basket strainer.
Mar 31, 2009 | Franke VNX-120-45 Vision Double Bowl...
Franke overflow waste connection
Once that fitting is damaged it is very difficult to repair. Try contacting Franke for nearest distributer and see if they will replace.
Mar 25, 2009 | Franke PAX-170 Papillon Undermount...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Franke /Kindred KIND KCFS30B/10 Designer Series Stainless Steel Apron Sink Logo
43 people viewed this question
Top Franke Home Experts
john h
Tom Chichester
Are you a Franke Home Expert? Answer questions, earn points and help others
