Question about Rubbermaid Pelouze FS32-88 2 lb. Compact Digital Portion Scale FGFS32
Pelouze fs32 won't power on - Rubbermaid Pelouze FS32-88 2 lb. Compact Digital Portion Scale FGFS32
Pelouze 4010 display only says 4010
This is not a camera - please repost in a more appropriate forum.
Apr 17, 2017 | Cameras
Fix my pelouze fs6 scale
Based on its appearance I'm guessing that you need to unplug it and open it up. Clean it as well as you can with a stiff brush and an electronics safe cleaner. Roaches are the most likely cause of your scales failure!
All the above may be fruitless, it may not be possible or worth the cost to repair.
Time for a new scale! You must keep it clean and turn it off and disconnect it when you aren't using it. Roaches like warm damp dirty places!
Apr 03, 2014 | Health & Beauty
I need user manual for the Pelouze Model PE5 postal scale capacity 5 lbs?
If i were you i would try to search for it on google or look on their website.
Oct 19, 2013 | Computers & Internet
When powered up the display reads 4040 and will not display anything else. buttons don't seem to function
We solved this hold down the lb/kg button and the zero/hold and the on button at the same time up comes a A-of and then do it again and it will come up CAL wait a momment and then turn off and it will go back to zero.
Nov 18, 2009 | RTO Pelouze Scale With Remote Display -...
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
I need to download the new postal rate on the scale, but I have no user manual or connector. Please let me know how to go about doing this.
Here is the answer on the Pelouze web-site you can also download a manual here. They have all of the software you need to get the rate change installed.
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=650
May 12, 2009 | Office Equipment & Supplies
PELOUZE 4010 SCALE READOUT FAILED
my pelouse when i turn it on it stays on 0.0 when i put weight on it stays on 0.0 it then goes of i need help to get it to work
Jan 28, 2009 | Office Equipment & Supplies
Rubbermaid Pelouze FS32-88 2 lb. Compact Digital Portion Scale FGFS32 Logo
26 people viewed this question
Top Rubbermaid Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Rubbermaid Measuring Tool and Sensor Expert? Answer questions, earn points and help others
