Question about Karcher 2500 PSI Pressure Washer
Hpw to put oil back into the karcher water pump K 4.80
4 Suggested Answers
  • 92 Answers
SOURCE: water in oil
Dear akwelectrica,
When a full kit was installed....WHAT was installed??? Were the OIl seals replaced?? Were the Low Pessure Seals Replaced?? Were the high Pressure Seals Replaced?? Was the OIL changed?? If the oil was changed...did all water in the oil compartment been removed?? Also did the suction and delivery valves were replaced?? Now if all these things were done, BUT the pistons were not changed, than the whole kit was done for nothing!! My suspicion is that the PISTONS were not changed. But if all the kit was used and even the PISTONS were changed, than you must for sure have a cracked or damaged head. When I say the HEAD...I am always refering to the part that holds the pistons. But in rare circumstances even the outer head could be damaged. Ask your "Service Tech" what he replaced and you will know the answear. As I said..I suspect that the PISTONS were not replaced by New Ones.
Regards,
fulltech.
Posted on Apr 12, 2009
  • 92 Answers
SOURCE: Can't fine where to put pump oil in
Dear glenoaks06,
I handled various Karcher washers, but the 2500 I never came across it. Just the same I will give you a few hints and maybe the solution for the problem. When the oil is milkey this means it has water in it. This means that there are faulty seals for sure. Now in many Power Washers the compartment where the oil is located is filled with oil prior to assembling the head unit that contains the pistons. So you have to take apart the the complete head change all seals( HP seals, LP seals and OIL seals). There are pumps that take multi-grade oil(15/50) and others 90 grade oil. If your pump is fan cooled, it probably takes 15/50 oil. Now one of the main biggest problem of water in oil is Faulty and Scratched PISTONS.
So when you have the pump apart....check condition of pistons. It is useless to change seals if pistons are damaged.
Now one thing regarding your problem, is that you have to put together the head with the pump upside down, so that you can fill the compartment (where the pistons are pushed by the swash plate), with OIL, before you put back the complete head with good pistons,springs,seals, valves...etc..etc. These few hints are relevant to quite a number of Karcher washers.
Regards,
Fulltech.
Posted on May 22, 2009
  • 56 Answers
SOURCE: How to put oil back into the Karcher water pump
You need to remove the pump and sit it brass side up before removing the bolts holding the brass to the aluminum part (you have to do it that way so the oil doesn't spill out.) CAUTION: there is some spring tension on the brass head.
Take the brass head off and set to the side on a rag or in a bucket. Dump out whatever oil is in the oil side, making sure not to drop the swash plate or bearing (the pieces sitting in the oil). Fill the oil end with aproximatly 4.5 ounces of Karcher pump oil, (or just 20w 50 weight non-detergent oil). Put the brass head back on and tighten bolts. Put the pump back on the machine.
If this helps please rate.
Bill
Posted on Jan 22, 2010
How do I fix a Karcher 2600 PSI pressure washer has water in oil..
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Aug 09, 2014 | Karcher G 2600 VH Gas Pressure Washer
HOW MUCH OIL DO WE PUT IN KARCHER3030B AND WHAT SORT OF OIL
you need to know where oil is coming from. pump or motor? both will use normal motor oil
Mar 30, 2014 | Karcher Garden
Oil type in Karcher gearbox
If you are talking about the water-pump gear box only, the correct oil type is 30W NON-Detergent oil. "ONLY"
Mar 15, 2014 | Karcher Garden
Karcher HDS 7/10-4M has the oil light giving 4 flashes, what does this indicate as the fault.
Ive got a brand new HDS 10/20 and its crapped out on me already, water line filters were blocked, cleaned them out and now it splutters after 2mins of pressure washing, oil light flashing x3, nothing in any of their **** manuals to assist, any ideas before i set it on fire?
Jan 19, 2013 | Karcher Garden
I have water in the oil in the comet pump/ZWD 4030. It is on a North Star 3000 hpw.
You have a seal failure, you need to reseal the pump and change the oil in the pump.
Nov 04, 2010 | Northstar Garden
Bill
Jan 22, 2010 | Karcher 2500 PSI Pressure Washer
Do I need to put pump oil on this k2400 I mean the
the water should take care of lube and cooling. word of warning...absulutely,positively,do not run this machine without water hooked up and running thru the pump. just a minute without water,and the pump will be junk!!!
Dec 21, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Dear glenoaks06,
Regards,
Fulltech.
May 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
70 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
