Question about Fuji FinePix S1000FD Digital Camera
Fujifilm S1000 wont turn on
It wont turn on if there's an SD card in. I've still yet to try an xD card but it turns on without a card in. If you put in an SD card of any brand it won't turn on
    Problem Solver:
  • 9 Answers
Your memory card slot is deifinately busted
Posted on Jul 09, 2009
Will an8gb compact flash card work in my finepix m603 camera
Your camera can't Please don't try to put any SD card in your camera. It will destroy the camera. You camera only accepts xD cards. It is a complete different card size and works different.
There are xD micro drives, but I would not buy them. it is a very small HD and are not made for years. So if you find one, it is likely it is defect.
But if you can find a 1 Gb xD card, you can put lots and lots of pictures on it.
The manual is still online
http://www.fujifilm.ca/shared/bin/Manual_M603_EN.pdf
Feb 12, 2015 | Fuji FinePix M603 Digital Camera
Camera shuts down after 1-2mins an does not take pics
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Nov 26, 2013 | Moultrie Game Spy M-880
Do I have to use a Olympus memory card or can I use a SanDisk SD card
You may use any brand xD Picture Card. The key is that it be an "xD" card, not the far more common "SD" card.
Apr 07, 2013 | Olympus SP-590 UZ Digital Camera
Everytime i put SDHC memory card in camera it shuts off... canon m1093 is
I've run into this problem with off brand or damaged SDHD memory cards. I just had another SD card go bad on me tonight. It happens. Sometimes they can become corrupted, and need to be low level formatted, and then sometimes formatted by the camera again before use.
Check out the SDHD card in something else, if you can. If it appears just fine there, then it may just be incompatible with the Kodak camera.
Try another SDHD card to see if it operates properly, which will most likely resolve the issue for you.
Feb 14, 2012 | Kodak EasyShare M1093 IS Digital Camera
When i turn on the camera it says xD Write Protect.
It can be that if you have a SD card in it you might have somehow clicked the protect small lever. if so take out the SD card and check the sides of it and see if you find a small square like lever then try sliding it up or down however it will go. My SD card has it and when I sometimes put my camera away I slide it to write protect mode so that if my kids somehow get a hold of my camera and play with it they wont erase my pictures. Then when I need to use it I slide it back to unprotected mode. Hope that is your problem.
Aug 08, 2011 | Olympus Stylus 720 SW Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Is olympus xd -picture card,type m+ 2gb compatable with camera Fujifilm Finepix.
XD cards are now obsolete memory cards. The cards were developed by Olympus and Fujifilm and released during the summer of 2002. There is now an adapter that allows an SD card to be used in place of the XD card You need to remember that the capacity should not exceed 2 GB or the camera will not be able to accept it. As far as I know cameras accepting XD cards were last produced in 2007, I don't know what specific models however the camera specifications would show what type card it uses.
Jan 15, 2011 | Olympus 1GB XD Picture Card...
I have a fujifilm JX250 camera and the battery is only lasting a day. i only bought this camera in November 2010 and barely take any pictures.
These cameras use both SD and XD cards. The SD cards are the cause of the draining. Switch to an XD card or remove your SD card while not in use and your batteries will not drain. :)
Jan 10, 2011 | FUJIFILM FinePix JX250 Digital Camera
I have a Fujifilm finepix digital S1000 fd camera. When I put in my batteries today, it said on the screen 'protected card'. How do I get this off so I can take photographs?
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 09, 2010 | Fuji Cameras
How do I delete all images on my SD card while
Got set up menu and then format. This should wipe them all out.
Oct 11, 2009 | Cameras
Fuji FinePix S1000FD Digital Camera Logo
519 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
