Question about Maytag PYE2300AY Electric Dryer
Dryer won't start
Dryer was running fine as usual. suddenly just stopped and would not restart. tryed again later and still would not start replaced door switch and still won't start.
  • 11,896 Answers
Are you getting any power to unit? The power supply most likely overheated and burned out a capacitor. It is possible that the relay may have gone bad to.
Posted on Jun 23, 2009
Dryer stops, restarts minutes later
It seems like clogged vent problem but as I always say The best method is to do your home work and you must do total trouble shooting procedure and replace defective parts if necessary and
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 07, 2013 | General Electric Dryers
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
1995 jeep wrangler just stops running without warning.
A bad crank sensor will shut the jeep off suddenly, while driving down the road, then restart later and it repeats over and over until you replace it.
Oct 12, 2012 | 1995 Jeep Wrangler
99 Elantra suddenly died
I'm not sure of this, but my friend experienced similar situation.
He had a Kia Pride used for Taxi cab. He have replaced damaged parts, replaced freon for his aircon and overhauled the engine. The cab really runs smoothly and in good condition.
But from time to time, the engine stops. Just like you, everything is normal, but stops unexpectedly. We even have it checked from my friend mechanic and said that everything is normal. He gave up the car and he loosed around PhP50,000.00 at that time (enough to pay rent for a year. He later found out that the car runs OK again...
THE NEW OWNER HAVE THE WIRING AND ELECTRICAL CIRCUITS RENEWED!
And a car owner claims for the same problem, I said its ELECTRICAL CIRCUITS, it should be replaced. When she have it fixed, the mechanic have her car's wiring replaced. And it runs smoothly again.
Please try...
Aug 22, 2012 | Hyundai Cars & Trucks
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
Jun 07, 2010 | Frigidaire GLER331A Electric Dryer
Suddenly stops showing the picture
The cause is a sudden overheat but when restarted its fine then it goes again this intermittant issue is with the lamp beleave that or not i found replacing the lamp solved the issue perm.
Thanks and please leave postive feedback..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 17, 2009 | NEC NP60 Projector
MY GSS23QGT JUST STOPPED WORKING
WR55X10942 is the part number for the main control board . The fan and heater have nothing in common . After you replaced the heater , did you defrost the coils with a hair dryer , or replace the heater and let it defrost it itself ?If you let it defrost itself , the heater could burn out again for being on too long .( this happened to me once , from then on , I defrosted with a hair dryer completely before restarting refrig . Main control board controls the fan . I've never had a bad fan motor , always been the board causing the fan not to run . The main control board will run about $150.00 if you install it yourself .
Aug 16, 2009 | GE GSS23QGT Side by Side Refrigerator
Maytag dryer stated when i push start button, then stop aft 10 mi
Hi, OK let me help. Do you hear any noise coming from the timer?
Whe it quit the first time, did it start right away or did you have to wait for a bit to restart it?
Vic
May 30, 2009 | Whirlpool LER4634J Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
145 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
