Question about Health & Beauty
Weight settings on model acs-f905 - Health & Beauty
Why will my bathroom scales, Model TH 321 not show weight, but only zeros?-
SOURCE:Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Jan 02, 2018 | Health & Beauty
How to set scale for weight only? How do you set scale for weight only?
Google
make model instructions
or
make model manual
or visit the manufacturer website and look for Support.
Oct 01, 2017 | Health & Beauty
Ferrari modena 360 model 2005 ac service
Do you have a pressure gauge, if so put freon in till the gauge reads ok, remember to have your AC on full when filling.
Jun 21, 2013 | Cars & Trucks
Ac high side is too high
Make sure the fan comes on when the ac is turned on. The system maybe overcharged. If the fan comes on take the truck to a shop with prober gauges and a vacuum system. have them remove all of gas and add the proper amount by weight. The weight should be on a sticker in the engine bay...
Aug 24, 2010 | 2001 Chevrolet Silverado
Powers on then off after self diag gives me a 2-2 error but how do i fix low voltage?
Check pico fused F904 and F905 for continuity. If either fuses are bad, suspect defective convergence ICs 8c01 and 8c02.
good luck
Sep 01, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Apr 24, 2009 | Conair WW60 Weightwatchers Scale
I have no manual or warranty
Mar 21, 2009 | Conair WW60 Weightwatchers Scale
Hitachi 50UX26B/27K 50 in.... Problem
Good Day, papamotts;
Won't turn check Q912, Q914 & I901. No relay click check Q003. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
7300 Series AC
***I guess nobody knows the answer. Ok. I'll search elsewhere.
Jun 14, 2008 | Heating & Cooling
TV weight
The trick to lifting Large TVs' is that they are very 'front' heavy, that is, most of the weight is in the picture tube...recall the "problem" of unstable TVs' from years ago (Children pulling down TVs')
If the TV is on the floor you can put a large pillow at the front (Picture tube face) on the floor & carefully tip the set forward onto the pillow. You can then measure the bottom of the set to see if it will fit on your stand. If you are concerned about the weight simply attempt to sit your body (180 lbs?) on your suspect stand..if it holds your weight your good...wiggle around to see how stable it is.
_________________________________________________Rick......
May 24, 2008 | Televison & Video
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
