Question about Cameras
I have a merch source lightblast projector model 1635224. I replaced the blub and it still does not work. Is there a manual somewhere?
The audio works on the unit. When I bought it (2nd hand) the bulb was burned out, so I replaced it. It still does not work. I would like to find some kind of manual or get some advise on a fix.
    Master:
  • 697 Answers
Stop buying burned-out bulbs. Whatsamatter4u? Buy a $9.99 voltmeter and see if there's power where there should be. C'mon, learn a bit of techie stuff...
Posted on May 15, 2014
2 Suggested Answers
  • 11967 Answers
SOURCE: Two Discovery kids cameras that do not work!!
Go to discoverystore.com and at the bottom of the page click on contact us.
Posted on Jan 06, 2010
Merchsource projectors
That projector doesn't have a VGA port, meaning that it's not made to be hooked up to a PC. I'm not sure if the low resolution is even capable with a modern video device. You could try rigging something up with one of these:
http://www.ebay.com/itm/like/281060973402?lpid=82
And one of these:
http://www.ebay.com/itm/12-Inch-3-5MM-Male-To-2-RCA-Female-Jack-Stereo-Audio-Cable-Y-Adapter-3S1-2R2-/290961857627
I still doubt that it will work but maybe worth a try noting the price of the adapters.
Dec 31, 2013 | HP Computers & Internet
Merch source projector wont show pix when laptop is pluged in
Are you using the HDMI output of the laptop? If so you need the HDMI drivers for it!
Jan 13, 2013 | Office Equipment & Supplies
I can't find a replacement bulb for my Shift3 Lightblast entertainment projector.
Hi mcboo...
Amazon is the right place for you. click here Amazon com replacement bulb for projector and choose some. (do not forget to ask the seller if fits to your model)
hope this was helpful.
enjoy
Jan 06, 2013 | Office Equipment & Supplies
Lightblast entertainment projector light does not come on
You can get a manuel at MERCHSOURCE customer service-i found the label on the underside of the projector and searched till i found a customer service link!!!!merchsource1635224 manuel was what i searched and went to
mscustomercare.com the original manufacturer!!!
Apr 22, 2012 | Air Tools & Compressors
Bulb Error
http://www.retrevo.com/support/Dell-5100MP-Projectors-manual/id/575bh227/t/2/
manual above. Also check, the Thermal Fuse, some have a little "Reset" button, to restore them check that. Also work through the troubleshooting section.
Mar 27, 2010 | Dell 5100MP Multimedia Projector
Projector lamp burn out
What bulb code (usually a 3 letter code) or the model number I cannot say. Sometimes that info is written on the inside cover that covers the bulb, sometimes it is in the instruction manual. It is almost always written on the bulb.
Apr 15, 2009 | Cameras
Connecting tv/cable box
This is a fairly common problem with this model. In most instances, it is just "slow" in sensing the presence of a video source as it cycles in its selection, internal DVD, VGA, Composite Video IN. Since it does not have a manual source selection, your only option is to really wait.
Verify that "Auto Source Select" is enabled in the Management Menu (buttons-Proj/Setup then >/9) and "tap" the "SRC" button on the projector itself to manually initiate the input/source selection.
Verify that you have done the connections correctly. Yellow RCA connector is the video while the red & white are the audio. Of course the Video input should be connected to the Video output, same goes for the audio. Please refer to pages 22 & 23 of the user's manual for more detailed instructions as well as illustrations.
A couple of things to consider: it is not HDTV capable and pls don't loose the remote.
If the unit will not select a source after some time (minutes), perhaps your best bet would be to seek replacement.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 12, 2008 | Radio Shack Cinego D-1000 Multimedia...
Search won't lock on to source.
Below is copy of my post to a similar problem.
Dec 23, 2007 | Radio Shack Cinego D-1000 Multimedia...
Optoma H56 - turns off just after start up.
It's not a short, the blub is near the end of it's life ~ the optoma is designed to detect when the blub is about to blow and shuts itself down. Turning the projector upside down or right side up usually only gives you a brief reprieve (some have reported a modest amount of extra time gained) on the blub ~ but in the end it's on it's way out and the projector will shut down again.
Oct 14, 2007 | Optoma H56 Multimedia Projector
Cameras Logo
157 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
