Why my door windows stopped working completely on 1997 acura cl 2.2?
Windows were acting up they would work and then they wouldn't and now they won't work anymore everything else works checked fuses they're good lil help please?
Is there should be a fuse curcuit for the rear defrost there may be more than one device that runs on this curcuit check the fuse, then the switch, then check the element on the back window
Wow, anything? everything? On my 1999 I found they have only one ground for the start/run system and that is a wire connected to the thermostat housing from the transmission loom. This came loose when the thermostat was replaced and would start running when I tugged on the wire (and completed the circuit).
Try disconnecting the battery cable again, but leave it off for at least 10 minutes. That will reset the computer, not sure if it will help w/ theft system though. Good Luck, Also try locking and unlocking the driver door w/ the key (not a remote) this may work.
i suggest you network & try diffrent auto repais because one tells you onething & another tells you another, i had a problem with my windows & i bought new parts that i was told i needed & in the end i stood with the parts because they waren't even the problem... perhaps its a fuse, ir your wireing is bent or not connected properly...
