Question about Tafelstern T704045 Tea Strainer Coffeelings
Tafelstern tea ware - Tafelstern T704045 Tea Strainer Coffeelings
Tip
How to disassemble & brew coffee using a Corning Ware P-146 or P-149 Coffee pot
Click on the photo below to read the original manufacturer's instructions on how to take apart & brew coffee using either the Corning Ware P-146 or P-149 coffee percolator. These early models are unique due to the outer pot lid threading directly onto the stainless steel coffee basket.
on Apr 09, 2015 | Home
Tip
How to properly clean vintage Corning Ware porcelain coffee pots & percolators.
Click on the photo below for the original manufacturer's cleaning instructions.
How do you use loose tea to make tea in a pot?
You can use steel pot to make a Tea, do you know Loose tea is very simple to make.
If you will use steel pot that is easy to hold and keep.
Feb 27, 2013 | Home
When making iced tea, what measurements of tea should I use?
Use the suggested amount of tea noted below:
3 Quarts - 5-7 bags or 2-3 Tbsp. of loose tea
2 Quarts - 3-5 bags or 1-2 Tbsp. of loose tea
1 Quart - 1-3 bags or 1/2-1 Tbsp. of loose tea
Sep 02, 2011 | Philips Senseo HD-7810 Coffee Maker
How can I remove burn stains from Corning Ware? It is on a teapot that burned dry.
Can you let me know if you found a solution? I was warming tea and forgot. Thanks. joe.packer@att.net
Aug 16, 2010 | CorningWare SC60 Slow Cooker
Can loose tea be used with this tea maker?
Loose tea can be brewed. I had researched more on the internet.
Jul 30, 2009 | Back to Basics IT400 TEA MAKER 2.5qt GLASS...
Tafelstern T704045 Tea Strainer  Coffeelings Logo
227 people viewed this question
Top Tafelstern Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Tafelstern Kitchen Appliances - Other Expert? Answer questions, earn points and help others
