Question about HP DeskJet F4280 All In One Printer InkJet
Why does hp deskjet f4280 print pages with missing text and lines?
Replacing ink cartridges changes nothing; nor does aligning cartridges.
    Master:
  • 673 Answers
Ink lines are clogged, sometimes unfixable, Try deep cleaning cycle.
Posted on May 15, 2014
SOURCE: HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Posted on Oct 22, 2008
  • 3 Answers
SOURCE: HP K850 cartridge problem
I had the same problem, all cartridges lights came on.
I did two things:
1st: I clean the print cartridges plugs with Q-tips, just to insure there wasn't any ink build on the plugs. If you look were the cartridges are, you will see four plugs one for each of the cartridges. Each plug has four contacts. They should be a bright metal color. If they dull in color, they have ink on them. Unplug the printer and pull all the cartridges out and gentlely wipe the the contacts with Q-tips. Re-stall all the cartridges.
Note: The cleaning did not solve my problem but its good maintenance since in was looking for a solution.
2nd: What work for me was I un-stall my printer totally. Turn off the printer then turn off the computer, had a cup of tea, rebooted the computer and re-install the HP cd disk and drivers, turn the printer back on. After I reinstall the software and put the printer back on my network, everything is working fine for the last two days. The lites are off and the HP toolbox is reading the ink cartridges status correctly. I believe that a virus change the printer drives.
Solution by;
eagleeye140
Posted on Apr 19, 2009
  • 17 Answers
SOURCE: Problem with HP Deskjet 5900. I have done all the
has this printer been sitting around and not been used? possible problem is that the cartridges or the jets are plugged with dried ink. use a damp paper towel and carefully wipe the bottom of the cartridges to remove any dried ink.
Posted on Jul 08, 2009
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Posted on Jan 28, 2010
  • 1751 Answers
SOURCE: I have two cartridges in
Hi
You can bypass the alignment on 5610 by pressing ok to start alignment
and then cancel
after that check by printing a document if your cartridges work fine if not
you can refill them with this easy and cheaper method
Posted on Jan 19, 2011
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
I just changed my ink cartridge on my F4280 hp printer, now my printing is blurry
Hello.
Try running the print head alignment feature through the computer. (Click Start - Control Panel - Printers and Faxes - RIGHT CLICK HPF4280 - select printing preferences - select maintenance - select cartridge alignment and follow the on screen instructions) This can also be caused by solid pieces of ink stuck inside the print head disrupting the flow. if it a genuine HP cartridge contact HP for a replacement. The link below shows how to clear blockages also http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps Regards GM
May 28, 2011 | HP DeskJet F4280 All In One Printer InkJet
How many pages can we print from a new #60 black ink cartridge
It can print upto 200 pages, Draft mode printing ( but you can assume it can print upto 120 or 140 pages maximum ( standard printing on A4 Sheet with 1.5" spacing between each line with standard 12 font size )
Jun 30, 2010 | HP DeskJet F4280 All In One Printer InkJet
New f4280 no blue ink as well
Yes, new cartridge would solve the issue. Also, if you want any help for replacing cartridges, please visit this link:
HP Deskjet F4280: Replacing Cartridges
Jul 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
I put new ink in my hp F4280 printer and I printed about 100 sheets and my light turned orange and it started printing slow. Can you tell does it need new ink already?
The ink level indicator is only an estimate. See page 72 of the user manual which you can obtain here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
The HP 60 holds enough ink to print approximately 200 pgs. By the way, it also can evaporate from the cartridge quickly too so try to keep a refill kit or new cartridge on hand.
Jun 08, 2009 | HP DeskJet F4280 All In One Printer InkJet
Ink problem
Sometimes it's cheeper to get a printer on sale than buying cartarages,
However remove the ink cartarages and clean the print heads off, sometimes this works.
Verify thay have ink.
and to save a little money get a referb cart off ebay I have had good luck getting cheep ink there
Apr 25, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F4280 All In One Printer InkJet Logo
90 people viewed this question
Seeker5211
Seeker5211
