Question about Dell Inspiron 1526 Laptop
My dell inspiron 1526 won't start up... and has a blank screen
How can i reboot my dell 1526.. it sounds like it's turning on but the screen stays black.
SOURCE: Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Posted on Oct 01, 2009
scott4169336
  • 103 Answers
SOURCE: dell inspiron 1000 never boots up, screen black
go into bios and fix boot menu
Posted on Dec 06, 2009
tbirdfan1
  • 3051 Answers
SOURCE: dell inspiron 1526 has problem (plugged in ,not
Hello there:
First you will want to ensure that the power cord is fully inserted at both the laptop and all the connections for the cord and that it is getting proper power. and check tosee that the connector thatthe power cord goes into is not loose if so this will have to be repaired
next remove the battery from the computer and unplug the power cord and then press in the power button for 1 minute than if this has a reset button on the back use a toothpick or a small item and pressin on the reset button for 30 seconds
now insert the power cord (NOT THE BATTERY YET)
and turn on the computer and it should now start up if so insert the battery and leave charge for 1 hour than you should be ok from here ok
Please keep me posted on this so i can assist you if needed.
Best regards michael
Posted on Dec 16, 2009
Ricky_Critic
  • 119 Answers
SOURCE: how to do a master reset on a dell inspiron 1526,
Step 1: Start up your computer and as the computer logo appears (such as Dell orHP) hit "Ctrl>F11" simultaneously. This may be different fordifferent machines, but the most common keys to hit are"Ctrl>F11." If this does not work, the F8 key has been said towork for certain machines.Step 2: Select "Repair My Computer" from the list of menu options thatappear and press "Enter."
Posted on Jan 04, 2010
  • 211 Answers
SOURCE: my dell inspiron 1526 turns on but the screen
oks just check the bios settings , the memories and the hdd getting detected if no then remove the ram clean it with an eraser and put it back, if yes then plz put a windows cd and repair your os or format it
Posted on Jan 11, 2010
How do i reboot a dell inspiron 1526 back to factory settings?
if its windows xp you hold Ctrl and F11 on startup
Sep 23, 2010 | Dell Inspiron 1526 Laptop
When I turn on my dell inspiron 1526 the screen stays black, you can hear the fan start, but it does not boot up
Try plugging a monitor into the VGA port on the back. If that works, then it's your LCD screen. If it doesn't then it's most likely your video card or your motherboard.
Aug 19, 2010 | Dell Inspiron 6000 Notebook
Restore defaults on Dell
Put the DVD with Vista on it in and reboot. Follow the promts on the screen.
Apr 15, 2010 | Dell Inspiron 1526 Notebook
No Sound
Changing back to XP means you will have to download sound card drivers for XP. These drivers are availble on Dell's website.
Mar 20, 2010 | Dell Inspiron 1526 Notebook
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
My dell inspiron 1526 turns on but the screen stays black, the power light turns on but the screen does nothing
Jan 11, 2010 | Dell Inspiron 1526 Laptop
How to do a master reset on a dell Inspiron 1526, but I don't have any of the discs.My computer keeps going to a page saying I have to type in my dell password. I do that and it goes to a black screen...
Jan 04, 2010 | Dell Inspiron 1526 Notebook
Dell Inspiron 1526 blank screen after hibernation
Press Fn Key plus POWER key ans see if the diagnostics will start. If no go, then the system is likely in a No POST state.
You can check the warranty status here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&cs=04&l=en&s=bsd&~ck=anavml
and no paperwork is needed to get warranty support, all you need is the express service code on the bottom and be a authorized user of the system.
Oct 21, 2009 | Dell Computers & Internet
Dell Inspiron 1526 LCD inverter unable to turn on lamp error message in diagnostics. PC boots up to login user screen and then goes black with the exception of the mouse prompt. It is visible moving...
Go on ebay and buy a new inverter for less than $10. Go on youtube to see how to replace the dell inspiron 1526 lcd inverter or the dell inspiron 1526 lcd screen. I put the lcd screen on because sometimes the problem might be your screen. If things don't work after installing the new inverter board, then buy a new lcd screen off ebay. The inverter board and screen are easy to install. Just go on youtube.com to find a video that walks you through it. The inverter sits at the bottom of the lcd screen. Some are screwed on, some are welded onto the screen, some are held by a small piece of tape. Even if you have to pry the old one off, just put the new on on held by a small piece of tape.
10results for Dell Inspiron 1526 inverter board
Dec 17, 2017 | Dell Inspiron 6400 Notebook
Dell Inspiron 1526 Laptop Logo
16 people viewed this question
Alun Cox
