My Gateway nv55c will not connect to my wifi. My phone connects to the wifi, and I can connect my laptop with an ethernet cable. When I try to connect to a ntework it says "windows was unable to connect to (network)." When I pull up the wireless network connection map it just says "the adapter is not connected."
    Sergeant:
  • 246 Answers
Try to remove / or disable ( disable wifi ) in control panel, and try to go on(enable) again
If still not solved, just contact to my email, i will helped you
Posted on May 15, 2014
  • 148 Answers
SOURCE: Can the Compaq Armada E500 go wireless?
hi,
any laptop has the capability to use wireless connection, if you connect to that laptop a compatible wireless card and install its drivers( the cd/dvd that comes with the wireless card)
to check if this card is ok or not try using it on some other laptop see if it works there and gets the networks
further Queries are welcome
Posted on Feb 18, 2009
  • 9 Answers
SOURCE: Unable to connect to ad-hoc network
do you have a wep code set up ?
Posted on Mar 02, 2009
  • 48 Answers
SOURCE: ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
Posted on Apr 14, 2009
  • 4 Answers
SOURCE: my asus eee won't connect to the internet via wireless
go to start and go to control panel,
then click on internet options, click on the advanced tab, and click reset, there you will find connectivity or internet or something, click on the cross which brings more info up, it should bring up atheos ethernet, and atheos wireless, delete/uninstall them both. then try to connect again.. should work.
Posted on Jun 26, 2010
SOURCE: My asus n61j won't connect to the Internet using internal adapter
Hi there, I just bought a new Asus NJ series, and all of a sudden my wireless dissapeared! I FOUND THE SULOTION, well, I hope it works for you. Look on the left side of your laptop, right at the front left side is a switch/button. I think I accidentally switched it of, but now everything is working fine!
Posted on Oct 27, 2010
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
Ethernet cable network doesn't work on my MP4000
You can use wifi OR ethernet, configure in user tools. -Carl
Mar 26, 2014 | Ricoh Office Equipment & Supplies
How to find wpa key
You can find the wpa key by loging into the router interface, and checking the wifi settings. You will have to be connected with an Ethernet cable or use a computer that is already connected to your wifi.
Start by getting the ip address of the router:
1.Press the "windows"+"R" keys (this will open the "Run" dialog box)
2.Enter "CMD" in the Run window, and press ok
3.In the Command Prompt window enter the following command "ipconfig" and press enter
4. locate the Ethernet adapter or local area connection if using an Ethernet cable. If you are using a wifi connection, you want to locate the wireless Ethernet connection.
5.Under one of those headings you want to locate the "Default Gateway" address. It will most likely be similar to one of the following: 192.168.1.1 or 10.0.0.1
6.Open a web browser and enter the address you found under the default gateway.
7.You will get a login page for your router. Usually the login formation is as follows:
admin/admin
admin/password
admin/leave the password blank
9.Once you have logged in you want to locate the wifi/wireless menu on the page.
10.Here you will find the wifi password
Dec 05, 2013 | Computers & Internet
Where do i find my ssid on my router
Out of the box your SSID should be linksys
You can find your ssid and change it by logging into the router interface, and checking the wifi settings. You will have to be connected with an Ethernet cable or use a computer that is already connected to your wifi network.
admin/admin
admin/password
10.Here you will find the SSID of your wifi network
Nov 28, 2013 | Linksys Wireless-G WRT54G Router
NV55C Gateway Lap Top cannot connect to wireless router
Does your WiFi work on the laptop work in another place... Starbucks for example? If so, then there is a software security issue with the router, you will need to call the ISP for adjust the settings. If you PC doesn't work with wifi at Starbucks then you have a software issue with your laptop. Go to MY Computer, Hardware/Devices and look for any yellow marks. There will probably be one where the wifi is located. (Expand all the devices by clicking on the plus "+ signs. Find the wifi modem, there are many mfrs; Broadcom and Atheros are two ones. Go into the submenus and driver update too and write everything down you find. The most important things are the description, model number, software version and version date. Navigate to the hardware mfrs site and download and install the newest drivers for the wifi modem. Re-boot and try again to establish a connection.
Jan 23, 2012 | Gateway NV55C03u Laptop
Cannot access http://192.168.0.1 in order to configure wep security as my network is unlocked
Open a command prompt, type "IPCONFIG", and look for the Gateway or the DHCP server. It may be different than 192.168.0.1, like 192.168.1.1, or 192.168.0.2, or even 10.0.0.1
Jan 23, 2010 | NetGear DG834G Router
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
Ubuntu WiFi
Your problem description is too brief, but try the following:
- Check if your wifi is turned on (there should be a button on your laptop)
- Check if your external wifi (usb stick, or whatever you have) is installed properly
- Check your IP address, if its in the same IP-range as your router's
- Check your gateway IP
- If you have access reset your router
It should work so far by now, if not:
- Switch to roaming mode
- Try to connect your laptop through an ethernet cable, if it works find out those settings (IP, gateway etc.) and use them with your wifi thing.
If this doesn't help, there is either a problem with your router or the network must be secured.
Nov 02, 2008 | Canonical Ltd. Ubuntu
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
David Payne
David Payne
