Question about Duravit 0929100005 Cistern Happy D. white for
How to fix Fowler K5 outlet valve
I have to lever for the half flush. How do I insert it?
Where to buy parts for Fowler toilet cistern .
adjust the float
you are looking for the inlet valve or diaphragm
not as much fowler out here as caroma system parts
ebay
large hardware stores
plumber
Oct 30, 2016 | Home
Fowler cistern. What causes flush buttons to stick?
normally wear and warpage
try sanding the edges of the sections, but the fix will be a new section in the cistern
Apr 08, 2016 | Home
Fowler cistern doesn't close off after flush
Adjust the screw to raise or lower water to make get it to work right. Some times the installation isn't put in right so it needs to be drained and loosed and set right before tightening down and turning water on.
Apr 08, 2014 | Home
Half flush does a full flush
It's not nessesarily a half flush just as little water as is possible for that toilet. The full flush has just a little more. It may be hard to tell the difference.
Nov 23, 2013 | Home
The lever (handle) to flush the toilet does not rise after it is pushed down, causing the toilet to run. One has to push the lever (handle)up after the down motion to make it function properly.
I had this issue as well with my toilet. My chain was unattached and had been sucked down the drain under the stopper valve preventing the toilet stopper valve from completely closing and causing the water to continually run. After re-attaching the chain I noticed when I flushed the toilet that the handle did not rise again until I manually pushed it up. After readjusting the chain to a tighter position where the chain was not floating at all but instead holding the stopper valve in place I again flushed to check the reaction. This fixed the issue of the water continually running and also the handle not resetting itself properly.
Here is the steps I took to resolve my issue:
Step 1: Remove the lid off of the tank.
Step 2: Check to see if the chain coming from the Toilet Handle to the Stopper Valve is loose, unattached, or broken.
Step 3: Flush the toilet and check to see if the problem has been fixed. If not readjust the chain to a different position and flush again.
Step 4: If all is resolved replace the tank lid.
Other possible things to check:
Check the Float Ball to see if it's Half-way or more submerged in the water. If it is it needs to be replaced.
I hope this helps!
Nov 08, 2010 | Toto Home
Half flush doesn't stop running
Yes, If I remember correctly you need to replace the flush valves. I cant remember if there is just one or two valves but they need to be replaced. go to your nearest plumbing supply house (a home improvement store will not carry it) and get a new valve. This will fix your problem.
Apr 21, 2009 | Home
How do i flush a radiator
go to auto parts store and get a flush kit,
cut and insert the "T" from the flush kit on the heater hose outlet or inlet.
make sure you are cutting into the heater hose coming out of the firewall heater area and not a large vacuum line.
if your not sure ask a mechanic.
connect the kits anti syphon to water hose and connect to the T you have installed ,
open the radiator , and flush very slow if engine is hot , or wait till engine is cool as a very cold flush can damage the engine.
Jun 18, 2008 | 1995 Chevrolet Lumina
Duravit 0929100005 Cistern Happy D. white for Logo
201 people viewed this question
Top Duravit Home Experts
Paul Carew
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Duravit Home Expert? Answer questions, earn points and help others
