Question about Jl Audio 1000/1V2 Car Amp
Why is jl audio 1000/1v2 in thermal but not hot?
Soon as i turn the deck on it does the second wait to check everything then the red thermal light comes on. Amp is not hot at room temp prior to installing.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
They might be using the light to show other problems as well. Or the unit you bought has the same issue??
Double check all your connections, leave it unplugged for 24 hours after hitting the power button several times to drain the capacitors to hopefully clear any codes in the modual.
Posted on May 15, 2014
5 Suggested Answers
SOURCE: jl audio 250/1 thermal light
i was having issues with this amp as well, the thermal light was flashing every couple seconds. i checked all the connections and i discovered that when i pulled the power wire out the thermal light was still flashing, which tells me that there was no power from the power wire, but it was getting power from the remote wire. i know this because it would stop flashing when i removed the remote wire. but wouldnt start when i didnt connect the remote wire but connected the power wire. so with the power meter i checked the fuse and it was a little loose so i screwed it back in and the amp turned right on.
to make a long story short, a flashing thermal light is a power supply issue.
Posted on Jul 27, 2009
SOURCE: jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Posted on Apr 07, 2008
  • 123 Answers
SOURCE: JL Audio 500/1 Amplifier "Thermal" light flashing
pooi
Posted on Jul 25, 2009
craigperry23
  • 185 Answers
SOURCE: i have a Jl Audio 250/1 mono block amp and the
It could be a number of things? 1 to many subs, speakers wired to the amp causing it to overheat and making the thermal light come on. 2 It all depends were your amp is. If it's clear and nothing covering it, obstructing it, Ie sub in front of it, amp inbetween the rear seats and sub.
Posted on Mar 04, 2011
Why my jl audio 1400d amplifier stays in protective mode?
Check for a speaker wire that come come of , Or a loose grond wire on the amp or where ever you have the ground wire connected two,
Oct 31, 2012 | Jl Audio Car Audio & Video
Have a jl audio 500/1 the red light blinks and no other light turns on. whats the problem with it?
I think you might have your remote turn on from your deck to amp hooked up wrong check that out!! I not are you familliar with the mr. butterworth crossover JL developed for that series of amp? Just like its big nrother the 1000x1 class D the built in smart crossover has many built in pretect modes. If your subs are drawing to much power it shuts down if they draw to little of ohms or to many but that 500 is 1 ohm stable so download the crossover settings from JL and go from there
Apr 28, 2012 | Jl Audio 500/1 Car Audio Amplifier
I have a jl 500/1 amp hooked up in my car and the power light comes on for about 5 seconds then turns off. no sound out of the subs. it is hooked up to a factory deck through a high to low level converter....
hook up the remote wire ( or make sure its hooked up good) check your ground! ground wire not big enough awg wire and put on bare metal not more than 1 foot away from amp. bad ground will cause this.
Sep 12, 2011 | Jl Audio 500/1 Car Audio Amplifier
Re-check all the connections to the speakers, The uPC monitors all the outputs and if any are taking more power than they should, the uPC shuts the amp down to protect the internal components. Don`t use tape joints alone, try to run the cable the full length without any joints. If you do have to piece the wires together, solder them and stagger the connections, in other words, make one lead shorter than the other so that if the tape does come off, the offending connection is well away from the other so they can never meet or connect to each other. Ian
Jul 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL A1800 Amp Not Switching On?!?
did you test for power at the amp, you should have 12 volts when the deck is on at the amp on the power and pto terminals. Also check and maybe reground the amp
Jun 05, 2009 | Jl Audio 1000/1 Car Audio Amplifier
I have a jl 500/1v2 and when i have the volume up for some time it teens to turn the amber color light on and turns off my amp and sub i turn down the volume for like 30 sec turn it back up and every thing...
its probably wires touchin or the ground not connected well with fat enough wire. i would try to rewire and do everything all over again because one wire or fuse is messing up i had t he same probelm. its the red light on the amp is ur amp shut off or ur warning light?
Jun 03, 2009 | Jl Audio E1200 Car Audio Amplifier
Jl audio 250/1 thermal light
Disconnect all speaker wires from the amp and disconnect the RCA cables from the amp. If it still goes into protect mode, use a multimeter to confirm that you have 12v on the B+ and remote terminals. Place the black meter probe on the ground terminal of the amp when measuring the voltage. If the voltage is sufficient and the amp goes into protect, it will have to be repaired. JL only accepts repairs from authorized dealers. You'll have to find one in your area or you'll have to find a repair shop willing to work on JL amps.
Let me know if you have any other questions.
Oct 15, 2008 | Jl Audio 250/1 Car Audio Amplifier
A300HLX Amp + 600 Watt JL Audio Sub
Ill go for a better GROUND , sounds like its not grounded properly and thats why the RED LIGHT . DO A RE CHECK on the installation . hope this helps
Apr 29, 2008 | Jensen A300HLX Car Audio Amplifier
Jl audio E6450 cutting out
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Jl Audio 1000/1V2 Car Amp Logo
64 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
