Question about Maytag Refrigerators
How do I put my maytag fridge model #mzd2667hew in diagnostic mode?
The fridge and freezer side won't get cold. Hardly any air blows into the fridge side. How do I put in into a diagnostic mode and then what do I do?
2 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
Posted on Sep 21, 2009
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
Side by Side Maytag MSD2542VEB00 freezer working but fridge is not
you took off the back inside freezer wall and the evaporator coil had frost on it?or was it even over the whole coil,if so that's what it should do,all that happens is that coil gets cold,the evaporator fan blows the cold air over into the fridge section and then there are air vents so the air just keeps circulating,in your machine you have a difusser or a damper part number W10151374,it opens and lets cold air in from the freezer and when it gets cold enough it closes,first thing open the freezer door,you should hear the fan blowing,if you don't you could have a bad evap fan motor,if the fan is blowing but no air blowing into the fridge then it sounds like you have a bad damper,if you open the fridge door the damper is up on the top left side wall,go here and this is a picture of it
http://www.repairclinic.com/PartDetail/Damper/W10151374/1454298 you can also go here and look at part number 4,this is your adaptive defrost board
http://www.searspartsdirect.com/partsdirect/part-model/MAYTAG-Parts/Refrigerator-Parts/Model-MSD2542VEB00/3048/0165000/W1203185/00011?blt=06&prst=&shdMod=
let me know what you find,also if you remove the bottom front kick panel,there should be a tech sheet to tell you how to put that machine into defrost manually,look for a paper tucked into the panel or taped inside that bottom cabinet that the panel covers
Jul 28, 2012 | Refrigerators
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Maytag MSD2651HEW refrigerator not cool, freezer works fine. If open both doors, feel cold air blowing in refrigerator side
try keeping the freezer door shut while felling for cold air blowing over to refrigerator side..if so problem lies in the thermostat...its not sensing the correct temp for the fridge side and closing the damper too early...also check to see if there is frost built up on the back wall of the freezer section if thats the case then you are at the begining stages of a defrost issue and soon no cold air will blow over to fridge side..let me know what you find
Mar 13, 2012 | Maytag MZD2766GES Side by Side...
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Refrig side not cooling....freezer side operating fine
Check that the damper vent that sends cold air from the freezer into the fresh food side is not blocked by contents. Check that the damper is opening to allow cool air to transfer. Put the fridge into diagnostic mode to check the thermistors.
Jun 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
Sep 21, 2009 | Maytag MZD2667HE Side by Side Refrigerator
Fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Feb 17, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
