Question about NAD C524 CD Player
Belt size for nad 524 cd player - NAD C524 CD Player
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Where can I get a belt for my NAD 5355 cd player?
Hi...
Try part# SBS3.0 from studiosoundelectronics.com
or a similar part at mcm electronics.
I just did one this week.
Posted on Mar 19, 2009
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
Nov 21, 2010 | NAD C542 CD Player
Disk drawer will not open
A small motor turns a belt, which then drives the gear that operates the drawer. Over time this belt stretches or breaks, and the drawer doesn't open. Replacing the belt cures the problem.
I've looked at the couple of belt catalogs I have, and nothing for NAD is listed. You'll need to measure the old belt circumference and thickness. Almost all of these are square belts, usually in the range of 2.5 to 3.5 inches circumference. If you're measuring the old belt, take off 10 to 15% since it has stretched.
A local electronic service shop may have a suitable replacement. Otherwise there are many sources online (MCM Electronics is one I deal with frequently here in the US). In a pinch, you can even use a small rubber band until you find the right replacement.
Hope this has helped. Thanks for using Fixya!
Feb 12, 2010 | NAD C542 CD Player
My NAD C 541 cd player will not play any discs. I open it put the disc in and it tries to scan and then rejects the disc and opens on its' own. There is the word 'over' in red below the track number...
It could be the belt for the tray mechanism. Tray closes then motor is pushed up to CD. If belt slips or physical mechanism is sticky CD will not spin and tray will reopen.
Nov 09, 2009 | NAD C542 CD Player
My NAD C251i CD player isn't reading disks - platform stops short
To fix it, you need to replace the spindle motor top bearing. The bearing is worn and the player mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. Because the disc is spinning fast.
Replacing the bearing should resolves the problem.
Hope this helps and have a great day!
Sep 01, 2009 | NAD C521 CD Player
I have a NAD 524 audio cd player , keep on skipping, some times its works perfectly ? what shall i do?
sounds like your lens is dirty as this happens on my awai cd player? try a liquid based cd cleaner kit in it ( follow the instructions though? ) or alternatively, unplug the unit, remove the casing and using a childs paintbrush and a small amount of isoprenol alcohol gently clean the actual lens and allow the liquid to dry, ( dont try using a cloth!) and refit your casing etc before trying it out? Also, depending on the bit rate sampling it may not be able to read certain discs if it is an old model? good luck.
Aug 14, 2009 | Audio Players & Recorders
Hi...
Mar 08, 2009 | NAD Audio Players & Recorders
NAD C542 CD PLAYER
maybe it is just the belt for the tray motor.
Jun 27, 2008 | NAD C542 CD Player
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
77 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
