Question about Canon Pixma MP480 All-In-One InkJet Printer
Communication error occurred. Check the I/F cable connection and power of printer. for adjprog.exe 1390 printer
SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
Posted on Mar 31, 2009
anjana03
  • 361 Answers
SOURCE: Can't print
frist u should check your printer port is install o r not in your computer . right mouse click on my computer then click onhardwere, then click
port,if not stall there is yello sign. instail it.
2/ if not work.re install softwere driver once a time.
Posted on Jun 20, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
pineworks
  • 4041 Answers
SOURCE: i turned power off printer in order to stop it
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 09, 2010
leethedeuce
  • 4472 Answers
SOURCE: Won't print Easy-PhotoPrint photos: Error
In the program try to go to file print, or the likes. What you need is the printer dialog box to open and make sure that this printer is selected in the pull box. Also depending on your operating system go to Start>control panel>printers(or printers and faxes). Make sure that the printer is set to default. Should have a check mark in a circle. If you can right click it and select set as default then that will make it the default printer. That should help you getting it to print. Otherwise I would delete the printer after downloading the latest drivers and reinstalling the printer. You can get the drivers/software from the link below just click it make sure on the page that opens that drivers & software is selected and then choose your operating system:
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx870#DriversAndSoftware
Only try reinstalling the drivers after you have tried my first suggestions.
Thank you,
Lee
Posted on Nov 18, 2010
What is error 004 and what do I do about it
This error refers to the communication error between the printer and its connection. To help you troubleshoot the issue, please follow the steps mentioned below:
-Turn the printer off using the power switch located on the printer panel.
-Wait 10 seconds, turn the printer back on, and check if the error message still occurs.
-If the error persists, reseat all of the toner cartridges. For more information about reseating toner cartridges, refer to the user's guide for your printer manufacturer.
-While reseating, clean the toner cartridges with clean cloth and verify that the orange plastic covers have been removed from the developer rollers.
-Turn off the printer, and disconnect the AC power cable and communication cable (Ethernet or USB, depending on set-up).
-Remove the Imaging Drum and verify that the developer rotor frame is not bent. If the frame is bent, please contact printer manufacturer to replace it.
-With the Imaging Drum removed, Open the front cover and then push on the toner cartridge handle to determine if the carousel moves freely.
-Reconnect the AC power cable, turn on the printer, and check. If the error still occurs, please contact your printer manufacturer for further advice.
GuruAid.com
Mar 28, 2016 | Office Equipment & Supplies
Adjprog.exe
You can get Adjprog.exe from here
http://www.imprek.com.ar/reseteadores/tx125_t25_tx135.rar
Solucionado AdjProg exe para epson tx 135 alguien lo tiene Impresoras...
Sep 15, 2015 | Office Equipment & Supplies
Communication error ' error coad 20000010 for epson 1390 printer
Hi Shwe,
Go To Below official Epson Printer Page For Your problem,
Communication Error
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
May 15, 2014 | Epson Stylus NX300 All-In-One InkJet...
Communication error 20000068
This error usually means the AdjProg utility you're trying to use is not compatible with your printer model.
There's some more information on the issue here:
http://support.printerpotty.com/2013/error-21000068
May 01, 2013 | Epson TM-T60 Printer
Epson stylus t30 error code 2100012c
This error is usually shown when using the AdjProg to try to reset the waste ink counter.
The error code is caused by one of the following:
1. More than one Epson printer is connected (turn any others off)
2. The utility can't connect using the "Auto" setting for the printer "port" (Select the specific printer port using the "Select" button).
This issue is covered with other AdjProg errors in this article
Jan 09, 2013 | Epson Stylus C84 InkJet Printer
System error e225
Hello 3G,
To resolve the issue Error e225,
Turn the main power switch off and then back on-ICMF 4000 series/D400 Series
or
Update the firmware :
There is a risk that the MF4150 will not operate if power interruption occurs
during the firmware update. Please make sure MF4150 is connected to
reliable AC power source.
1. Save the downloaded file "MF4150_FirmwareUpdateTool_V0xx.exe on local drive. (i.e. desktop)
Computer Requirements for update
- Microsoft Windows 2000 or XP (32bit)
- Equipped with a USB port (either 1.1 or 2.0)
- Free disk space: 100 MB or more
2. Make sure that Processing/Data indicator (Green LED) on the MF4150's operation panel is turned off.
If the light is lit or blinking, wait until all the jobs are finished (i.e., COPY, PRINT, and SCAN), and that the Processing/Data indicator is turned off.
3. Make sure that Error indicator (Red LED) on the operation panel is turned off. If Processing/Data indicator (Green LED) is lit and Error indicator (Red LED) is blinking at the same time, jobs are held in the printer memory due to an error, possible cause is out of toner or paper has run out, or toner cartridge is not installed. Check the LCD for and error message and refer to the documentation that came with the printer to resolve the error.
4. Disconnect Fax line cable from the MF4150 to prevent Fax reception interruption during firmware update.
5. Make sure the USB cable is directly connected to the MF4150 and your computer.
  • Do NOT use a USB hub to connect the cable, as it may lead to a connection error.
  • Make sure the machine is not in the Sleep mode (i.e., [Energy Saver] key on the operation panel is leit). To exit the Sleep mode, press [Energy Saver] and confirm that the Energy Saver light is off.
  • You need to log on as an administrator to perform this update.
  • Make sure that no other applications are running on your computer.
6. If [Found New Hardware Wizard] appears on your PC screen, click [Cancel] to exit the screen.
  • [Found New Hardware Wizard] screen may be displayed multiple times. Cancel anytime you encounter this screen while performing this update.
7. Double-click ?MF4150_FirmwareUpdateTool_V0xx.exe? that you downloaded and saved.
8. Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
9. Confirm that the machine is in the ready status, and then click [Transfer]
  • If the printer is not detected: Check if the printer's power is turned on and the USB cable is properly connected. Then click [Retry] to proceed.
10. The firmware is transferred to the printer.
  • Never turn of the power to the MF4150 while firmware is updating. If power interruption occurs while the firmware is being updated the control board will be damaged and will need to be replaced. The replacement of the control board and labor will not be covered under warranty.
  • If an error occurs while transferring the firmware: Check if USB cable is properly connected. Click [Retry] to proceed.
11. When [Firmware transfer is complete] appears, click [Exit].
The printer starts the update process automatically.
<ERASE FLASH ROM> appears on the printer's display while the existing firmware is being erased.
Then printer's display shows <FIRMWARE UPDATE> while updating the firmware.
When the firmware update is complete, the printer's display shows <FIRMWARE UPDATE OK> <MACHINE POWER OFF/ON>
12. Turn printer's power switch OFF, wait 2 seconds then turn the power switch back ON. Check that there is no error on the printer display. Reconnect removed fax line cable.
Jun 22, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Hi, I just installed a given Stylus C46 and the green (power) and red (ink) led light alternativly. I try to print something and nothing happen... What can I do ?
Dear friend,,
It's because of the EEPROM Error.Try the following program.
http://www.mediafire.com/?xydczelivyi
download it.Run ADJprog.exe.select printer model Epson c46,destination asia,Port usb or Something you've connected.Click ok.Select Cosumables maintanece counter click reset.
Hope it'll help
Mar 07, 2011 | Epson Stylus C46 InkJet Printer
Epson 1390 service is required.
download free software resetter epson stylus photo 1390
Jan 10, 2011 | Office Equipment & Supplies
Canon Pixma MP480 All-In-One InkJet Printer Logo
229 people viewed this question
old marine
old marine
