Question about Pyle PLD175TBT Car DVD Player
Why is the display always on?
I have a Pyle PLD175TBT and when I turn the key off, the display shows "ACC WAIT" and then "ACC OFF", and then it stays on. Do I have something wired wrong? It's not supposed to do this is it??
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Sounds like it is recognizing it, so probably wired correctly.
Browse the owners manual for the settings, you might have them set wrong.
Posted on May 15, 2014
  • Kevin Price
    Kevin Price May 15, 2014
    Already looked through it, and through it's "Troubleshooting" section. Couldn't find anything useful to this problem. :(
I am wiring a Pyle PLMRKT36WT. There are two power source wires. ACC and POWER B+. What is the difference between them and how should they be wired/switched.
didnt specify vehicle --acc is an accessory port or line which goes on and off with key --power b+ is constant power positive side of battery continue live
Jun 10, 2017 | Pyle Car Audio & Video
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
When i turn on the car the radio doesnt go to the home page it goes to a screen with circle and arrows number 1234
You have the unit wired wrong. When you shut your key off the radio loses ALL power and it needs ACC power to maintain the memory. If not, the unit will reset itself. The screen you see is the touchscreen calibration screen. Just follow the " X " around the screen to 5. Then the unit will boot up again. You will have to reset radio stations and EQ and speaker settings. If you don't fix the ACC wire, you will have to do this A LOT!
Dec 06, 2013 | PYLE Audio PYLE PLDNV695 6.95 DOUBLE-DIN...
Reset change oil light
Driver Information Center (DIC) Equipped
Step 1 of 5
Place the key in the ignition and then turn it to the On/ACC position with the engine off.
Step 2 of 5
Press the "mode" button on the DIC until "Oil Life Left/Hold Set to Reset" is displayed on the DIC screen.
Step 3 of 5
Press the "set" button and hold it down until "100%" is displayed on the DIC display screen.
Step 4 of 5
Wait until three brief chimes emit before turning the ignition key back to the off position.
Step 5 of 5
Start the engine of the Aztec to ensure the oil warning light ("Change Engine Oil") is no longer illuminated on the instrument panel. If it still is, repeat the procedure.
Non-DIC (Manual Change Oil Light)
Step 1 of 4
Insert the key into the ignition and turn it to the ON/ACC position with the engine off.
Step 2 of 4
Step on the accelerator pedal fully to the floor three times within five seconds.
Step 3 of 4
Turn the ignition key to the off position.
Step 4 of 4
Start the engine to ensure the oil warning light is no longer illuminated on the instrument panel. If it is,repeat the procedure.
Aug 22, 2013 | 2003 Pontiac Aztek
Cant enter radio code .it shows off.volvo v40 2001
turn your ignition key to the first position acc and wait for 2 hrs, then you radio will show code again turn the middle knob to the proper number and push it to enter, it will jump to the next one and so on good luck!
Mar 02, 2011 | 2001 Volvo V40
MEMORY FULL ON SHARP UX-460
In addition to clearing memory this *will reset unit to factory defaults.
*****all of your programmed settings will be erased.
First power down the fax by unplugging, then power on.
After the power is turned on and "WAIT A MOMENT" is displayed, press & hold the STOP key.....until a normal display message shows.
*The above step allows the memory to be cleared! If this step is skipped clearing memory to factory defaults, (below) may not always work.
Press the "function" key followed by ALL of the following
9 * 8 # 7
wait until "diag mode" is showing.
Then press start button, followed by either * or #
until "memory clear" message is displayed.
then press start. If stressful "memory cleared" is shown.
proceed to re-program your fax machine settings.
Oct 20, 2010 | Office Equipment & Supplies
I have a hyundai radio 5064 and I want to change the time on it?
I have an 02 Santa Fe with 5064 radio. Here is what works for me. Key to ACC.
PWR on radio to OFF (display time only).
Press & hold { 4 D- } & { DISP } button simultaneously for about 3 seconds. Time will blink. If time does not blink, turn key to OFF, back to ACC & start over.
With time blinking....
Press { TUNE/SEEK UP } (double arrows) button to get desired hour.
Press { TUNE/SEEK DOWN } (double arrows) button to get desired minute.
Once set, wait a few seconds for time to stop blinking & your done.
Jul 17, 2010 | 2002 Hyundai Santa Fe
How do I do a Diagnostic System Check? Is this
If you can visit one autozone shop, they can read or scanning your OBD codes.
Codes are displayed on digital odometers on newer models. On many 2001 and newer models, holding in the trip odometer reset button while turning the key to RUN will start a self test, with a readout on the odometer. It will also activate all instrument panels, one at a time. We do not know if this will show computer codes, or whether it only tests the instrument panels. At the end, it may show a few odd codes that are firmware versions and not error codes.
On most cars, the codes will read out if the engine light is on - all you have to do is put the key into the RUN position.
Normally, to get codes, you put the key on OFF and then rapidly do OFF-ON-OFF-ON-OFF-ON (on some cars you have to do four or five, not three, OFF-ON cycles). On our test 2002 car, the key did not go back to unlock, so it was ACC-ON-ACC-ON-ACC-ON.
  • You may have to have the parking brake firmly set for the codes to show! (Thanks, Steven Midway)
  • Jon Yoon: The 1998 Caravan does the same check engine light code trick, but it also does an instrument diagnostic check if you hold the trip and reset buttons and turn the key to the run position and wait 5 seconds. This helped me figure out that my input and output speed sensors were broken but the actual speedometer dial could move.
  • For the 1999 Jeep Grand Cherokee and up, you do the switching the key on and off 3 times, but not quickly. You turn it to on so the odometer turns on, turn it off, and then back on, wait for the light to turn on, etc. On the fourth time you'll get a code, or you'll get the word "done." (Monica MacDonald)
A loose gas cap may light up the Check Engine light! (Thanks, Lyn Clark)
  • When the computer indicates major failure, it can activate Limp In mode, which guesses about data to compensate for sensor failure, allowing you to get the car to a mechanic. One major symptom of this is the transmission sticking in second gear. This is a feature!
  • 2002 Ram, put transmission in neutral, parking brake on, then do the acc-run key sequence 3 times.
  • Dan Stewart wrote about the 1999+ Voyager/Caravan with digital gear selection display:
    • There are 2 functions that can be accomplished with the key-on sequence. Get Diagnostic Trouble Codes by placing the key into the ignition. Push and hold the both the "Trip" and the "Reset" buttons with the left hand and turn the key to the "ACC" position (first position between "LOCK" and "RUN"). Continue to hold both buttons in and count to 5. Release both buttons, display should read trip mileage instead of total mileage. Push the "TRIP" button and the odometer will display DTC'S in rotating sequence instead of displaying total mileage.
    • The second function is an instrumentation diagnostic. Place key into ignition, press and hold both "TRIP" and "RESET" while turning the key to the "RUN" position. Continue to hold both buttons in until odometer displays "CODE". Release buttons. The display will then display "999". Afterward it will display "CHECK 0" and test the analog gauges. It will then display "CHECK 1" and test the digital displays
RESET THE COMPUTER
Normally the computer will eventually reset itself; you can also use a scan tool. (See our transmission repair page for information on resetting the computer's transmission information.) Disconnecting the battery for a few minutes generally resets the computer, though it also means losing clock settings.
Sid Willoughby wrote: “To clear the check engine light on a 2002 Dodge Ram once the problem is resolved. Start the engine and drive forward then in reverse (you only have to move the truck a few feet in each direction) the turn the ignition off. Do this sequence three times. When you start the vehicle the fourth time the check engine light should go out.” (This procedure may well work on other vehicles.)
CODE LIST 2001 which covers some vehicles from the late 1990s as well as newer ones. It shows the longer codes starting with the letter P.
Hope this help (remember comment and rated this).
Apr 09, 2010 | 2001 Dodge Caravan
My 1996 Pontiac Sunfire wont crank...
tryy replacing the fule injectors and the fuel pump could possibly be shot as well. you have a fuel problem.
May 07, 2009 | 1996 Pontiac Sunfire
WILL NOT TURN OFF!
yes. the probs you bought a pyle. lol. the speakers were good back in the days but the electronics really suck and thus you get prlike you do BUT it seems like your installation technician did something wrong. once you turn your car off the unit should shut off. its probably hooked up to a negative ground or wrong wire.take it elsewhere before your car burns.
Dec 23, 2007 | Pyle PLTDN71 Car Video Player
Pyle PLD175TBT Car DVD Player Logo
57 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
