SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
SOURCE: Can't print
frist u should check your printer port is install o r not in your computer . right mouse click on my computer then click onhardwere, then click
port,if not stall there is yello sign. instail it.
2/ if not work.re install softwere driver once a time.
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
SOURCE: i turned power off printer in order to stop it
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Won't print Easy-PhotoPrint photos: Error
In the program try to go to file print, or the likes. What you need is the printer dialog box to open and make sure that this printer is selected in the pull box. Also depending on your operating system go to Start>control panel>printers(or printers and faxes). Make sure that the printer is set to default. Should have a check mark in a circle. If you can right click it and select set as default then that will make it the default printer. That should help you getting it to print. Otherwise I would delete the printer after downloading the latest drivers and reinstalling the printer. You can get the drivers/software from the link below just click it make sure on the page that opens that drivers & software is selected and then choose your operating system:
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx870#DriversAndSoftware
Only try reinstalling the drivers after you have tried my first suggestions.
Thank you,
Lee
