Question about Vinpower Digital Computers & Internet
Vinpower Digital Vinpower Digital Burner- manual
Just received the Vinpower Digital Vinpower Digital Burner Bundle: External USB 3.0 DVD CD Burner + OQ DVD-R 10 pcs- Having difficulty copying audio tracks from computer memory- Need instructions... None came with order... harvey-vaughn@hotmail.com Phone 313-318-7503
    Sergeant:
  • 376 Answers
Please explain what this term means: "copying audio tracks from computer memory". In normal operating you don't copy audio tracks you burn them to the disk using a compatible burning software.
Posted on Jul 03, 2014
  • 2427 Answers
SOURCE: lacie external dvd burner not detected
DO YOU HAVE THE DRIVERS FOR THE BURNER CORECTLY INSTALLED ?
TRY IT ON A DIFFERENT COMPUTER TO SEE IF IT WORKS.
IF IT DOESNT YOU MIGHT NEED TO CHANGE EIGHTER THE DRIVE OR THE BURNER
Posted on Dec 30, 2007
  • 1019 Answers
SOURCE: My computer will not recognize my DVD burner
I,d suggest Obtaining A $19.99 Premium Support Package from This Site. Where I,m Sure One Of our technical Experts Will Resolve The Problem Within 24 Hours.
Mike @ Compurepair.
p.s I hope You set it Up, in The bios Correctly :)
Thankyou for Using FIXYA.
Posted on Mar 02, 2008
SOURCE: Sony DVD RW AW-Q170A Burning Problem
1. pl confirm ur drive as as sony as AW-Q170A
2. Download both file necflash_wingui.zip and 113bt_rpc1.zip
3. If ur not sure about drive being master or slave turn all the IDE to PIO mode. Pl remember flashing will not be possible if in other mode.
4. Unzip the zip file
5. Run necflash dump the firmweare file at safe location and flash the bin file with 113Bt_prc.bin.
6. Reboot in safe mode. Restore IDE to original mode.
7. Reboot and start normally. Bingo prob is solved
Posted on May 01, 2008
SOURCE: lg 20x external super multi dvd rewriter - not working
STUPID!
Please refrain from giving technical advice if you no NOTHING about the hardware in guestion. This is an SATA drive, early1234, master/slave is not part of the BUS.
IDIOTS out there, misinforming!
Posted on Nov 13, 2008
semperfly
  • 3 Answers
SOURCE: Problems with Micro Solutions Backpack CD-RW/DVD-ROM Burner?
Try this.
http://www.micro-solutions.com/downloads/index.asp
Posted on Mar 25, 2009
I am trying to replace the optical drives, but cannot figure how they slide out. Cannot get the front cover off, and it appears they do not have clearance to be removed from the rear. Mehod for this?
Most PC's are the same. The front cover is removable. Most have taps and some swing once the tabs are released. See photos.
The dvd in almost all cases removes from the front. Start the removal by either removing the screws or releasing the tab Slid the DVD out s little to facilitate the cable removal.
Hope this helps?
26214332-hbkptpu4rouqiogb1anremyp-5-9.gif 26214332-hbkptpu4rouqiogb1anremyp-5-0.gif
Jun 07, 2016 | Vinpower Digital 1 to 7 LightScribe Dvd /...
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
Where to get this printer in china
HP makes a printer that prints directly on a DVD or CD disk
Dec 03, 2013 | Vinpower Digital Blu-ray/CD/DVD Inkjet...
The controller only burns to 4 out of 5 drives and 1 of the 4 working frive keeps making burn errors. Is it time to install new firmware to fix this? or do i have to install new drives? Can i install...
Hi I have this problem with my systor 0-3 target duplicator, the one tray works fine, the middle one keeps making burn errors and the bottom one won't burn at all I can't seem to find a solution
Sep 20, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
Can a DVD-R Speed 16X be changed to 4X the 16X speed will not play on my TV
Yes
1) Open My computer or Computer
2) Right click on the DVD
3) Click on recordings
4) On the bottom - it will show you the an option to select the speed 7a60bfc.jpg
Jan 10, 2010 | Sony Vinpower Digital SharkCopierHDD to 8...
My lap top already has a dvd burner that is playing up, I've bought a second hand dvd burner without an installation cd, how can I still activate the external burner?
You can still use and activate your external burner. Most external DVD burner drive is USB right? So you just plug in the usb plug of your burner in your laptop and it will automatically detected by the system and install the neccessary driver for it to work properly. If you do have an existing burner software in your laptop then you can also use it for burning DVD's and CD's to your external burner but if you don't have any, then install a burning software like NERO or any. Hope this could help you. Please don't forget to rate me..:-) Thanks..
Nov 05, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Dvd burner won't burn!
do you still have the software for your external dvd...if so...uninstall it....now start all over like it is brand new...reinstall and reconnect the dvd....this shoud do the trick...
FYI
all dvd movie take 2-3 hrs to burn (some even 4 hrs..depends on the lenght)...and for the future never just turn off any data transfering devices....not even your pc when windows is updating....
May 25, 2009 | Lite On LITEON USB 2.0 EXTERNAL 52X32X52...
Manual Needed
hello i would like to know how do i duplicat a cd
Jun 30, 2008 | Vinpower 16x CD / DVD Duplicator with...
Vinpower 1 to 4 not seeing 4th drive
I would make sure all the cables are secure and possibly reconnect them to ensure a good fit. Do all the drives show up in the BIOS or Disk Manager? If not and they are all connected, it may be defective. Also check power connections, does the light on the drive work at all?
Mar 28, 2007 | Vinpower SharkCopier 1 to 3 (VP4690PIO103)...
Computers & Internet Logo
79 people viewed this question
Top Vinpower Computers & Internet Experts
jhnolson
solver2010
Are you a Vinpower Computer and Internet Expert? Answer questions, earn points and help others
