Question about Spectre 2002 Chevy Tahoe - 5.3L V8 - Air Filter
Installing a 2002 chevy tahoe air filter - Spectre 2002 Chevy Tahoe - 5.3L V8 - Air Filter
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Umm, there are 4 screws, sometimes a #3 Philips, or a t25 Torx, you will need along handle as there are 4 screws and two are down in there deep. carefully lift the top portion to replace the filter, and then screw it back down.
Posted on May 15, 2014
A/c clutch wont engage on a 2007 chevy express van with a 4.3
it could be low on refrigerant or overcharged, it cold be a bad wire or plug on the compressor it could be a blown fuse or the ac switch
Sep 18, 2013 | aFe 2007 Chevy Express - 4.3L V6 - Air...
Air filter install
The sensor sounds like the MAF (mass air flow) and if it is ... you need it! The car will run without it ... but then it should trigger an OBDll code after awhile .... so depending on where you live ... you will not pass a smog test ... if you are in certain USA states
Feb 15, 2018 | Spectre Performance - 9735 - PowerAdder P5...
Recently Ive started smelling gas or exhaust fumes when my 96 Tahoe is sitting and crunk up! What could this be?
If you are smelling raw fuel i would check the fuel pressure regulator.Pull the map sensor vacuum hose off and look for fuel in the hose and also look in the air intake pipe for fuel if you see any in either of these two components then replace the fuel pressure regulator.
Oct 30, 2012 | AM Auto Parts 1996 Chevy Tahoe 5.7L...
Where is the pcm/vcm location on 1999 chevy tahoe?
Shift the vehicle's transmission into park (automatic) or first gear (manual transmission). Turn off the engine, then rotate the ignition back to the "ON" position, but do not start the engine.
Connect the scan tool's data communication cable to the vehicle's diagnostic data port underneath the dashboard, above the foot well area.
LET ME KNOW THIS HELPS
Sep 17, 2012 | AM Auto Parts 1999 Chevy Tahoe 5.7L...
My car is smoking out of the exhaust why?
WHITE SMOKE - Have the mechanic check if the Head gasket has blown.
Sep 12, 2012 | Spectre 2002 Chevy Malibu - 3.1L V6 - Air...
Still getting dust build up after installing an IQ air system
You will need to run an actualy HEPA filtered air filter as well. The air purifier will oxidize pollutants and will attract and trap some small dust, but most small units also require additional filtering to trap inert neutral charged dust.
Feb 03, 2012 | IQAir Air Purifiers
Car dieing
You may have a Vacuum Leak, Throttle Position Sensor may be bad, and the MAP Sensor. Those are know to go on the 3.1L Chevy Lumina's. Thank you for using Fix Ya! Don't forget to rate the overall rating of this answer. Good Luck.
Jun 30, 2008 | Blueair Blue Air 402 Smokestop Particle...
Spectre 2002 Chevy Tahoe - 5.3L V8 - Air Filter Logo
Top Spectre Air Purifiers Experts
 Russ Hill
Russ Hill
Bill Boyd
Lawrence Oravetz
Are you a Spectre Air Purifier Expert? Answer questions, earn points and help others
